How to bind the Mini Remote [Serious]
The 2.4GHz Mini Remote is my favorite transmitter for esk8.
(buy from amazon)(buy from UK)(buy receiver only from AliExpress)(buy from AliExpress)
To bind a receiver with a transmitter, you can follow the steps in this excellent video from @torqueboards
I’d like to add that there is a failsafe trigger position (the throttle value used if signal is lost briefly). To set this, you leave the receiver and transmitter on after releasing the bind button – at that moment you set all the controls to the “failsafe” position you want them in if signal is lost. The moment you remove the bind key, the failsafe position is recorded for both channels. Then turn everything off and back on. You should be rocking and rolling.
One of the many reasons I like it so much is because it’s extremely easy to use one transmitter with more than one receiver.
So, to review, with one transmitter and one or more receivers,
  • Ensure everything is off.
  • Insert the bind plug(s) into Channel 4 on all receivers.
  • Power on all receivers.
  • Hold the “bind button” on the transmitter.
  • Turn the transmitter on, wait a few seconds for bind to happen, then release bind button.
  • Put the trigger and wheel where you want them for failsafe. In most cases, this means turning the white fine-adjust knobs to center and not touching the wheel or trigger. Remove all bind keys to set failsafe.
  • Turn the transmitter and receiver(s) off.
  • Verify it works.
Then, one of the possible next steps would be setting up Ackmaniac firmware on a VESC, or some other form of ESC setting and calibration.
2022 update:
2023 update:
The Mini is still fine for rural areas but I highly recommend the Z.Mote instead.
4WD x Landwheel x Bustin Cigar x 8s6p
Best budget remote
WTB budget remote
Calibrating PWM ("PPM") servo remote control [SRO]
Archived: the OG noob question thread! :grinning:
Autism friendly EMTB experiences (UK, South)
OSRR - A High Performance Open Source Racing Remote for ESK8 - [LEGACY}
2 remotes for 1 esc.. this IS how its done!
Help random cut out with vesc faults
Mini remote, a retrospect.
ChortL | 29.75" John Grigley | 3WD | TB130 | BN145 | 10S | 100 cells [SRO]
Ghost acceleration
[WTS] [US] Mini Remote Battery Cover Screw
Remote and receiver (Europe)
Wanted items cheap or free
[Help] e-Mountainboard with Hoverboard Hubs and Mainboard - EmanuelFeru Hack
Could use a bit of help, hope this is the right place.
Old Build, New Motivation
[AU/WTS] parting out metroboard single
[WTB][US] Remote with Reciever than can connect to vesc
I was part way down a 11% grade bike path when my remote died.
Build thread for Electric Roller Skis
Compatible parts to wirelessly achieve one remote paired with two receivers?
Remote by PotatoSkaters is (almost) here [SERIOUS]
WTB - EU - Remote that can bind to 2 boards
Space Cowboy | Prototipo | 12s5p 40T | Hypertrucks | 6396 140kv | Neptune BMS | Unity
Remote Controller for FOCBOX Unity
How to: Ackmaniac ESC Tool
Carbon GTO | 10S4P | TB110 78A | dual FOCBOX 1.6 | dual enertion 6355 | Boardnamics 220 | Carbon GT deck [serious]
Vesc tool 2.0 hfi help
The Green One | 29.6" Powell-Peralta | TB110 | dual 6355 | Caliber 2 | 10S 14500mAh [serious]
Help! Getting strange board behavior
First but not the last
Mini remote mod with thumb control
Inexpensive Remote in 2020
Are the flipsky the best budget remote?
Maker-X remote with lights control [Serious]
I need a alien power systems remote
First build! | New to esk8 | Parts check
Mini remote ppm patchy signal
4wd set up options, what do you do?
Non-signaled board motion
Let there be ESK8 lights
Mini FOC based on VESC6
Changing up a metroboard to a semi diy
Dual VESC setup help
Is mixing VESCs OK?
🏁 SRB Esc Approach 🏁
Evolve Gen 1 Revive (parts help)
Split PWM ("PPM") settings
New shredlights
Forum Adjustments and Updates
First build...ever! (NYAKIM 1)
Good that you mentioned how to set the failsafe!
Something which is not so easy to find information about.
Man, whats going on with @b264. First a build thread…now a tutorial…You must have had a good v-day ehhh??
excellent tutorial! :slight_smile:
@b264 this is great, nice work!!!
my fav too i cant ride with nano lol
two years and exactly 0 issues with this remote.
Where the hell are your avatars?
do i gotta pay to get an avatar?
Yes, x1 set of direct drives, as soon as I get them I’ll unlock you avatar controls :smiley:
@mmaner I flagged your post for greatness. :muscle:
ROFL, that’s good stuff :smiley:
I’m pretending to troubleshoot the issue. I should have a meaningless and implausible explanation that lays the blame squarely on your shoulders in a few hours.
@longhairedboy WHERE MY AVATAR! SLACKER! :sleeping::sleeping_bed:
I have to assume it was a service outage on the third party letter avatar service discourse is proxying. Seems to be working this morning.
I blame @torqueboards for the outage. He was probably hoarding all of the avatars for resale later.
I’d like to add that when you use the Mini Remote, the power switch on the transmitter is the weakest link in the system so BE EASY when you turn it on and off for a long lifetime. Don’t caveman the switch on and off because it will break.
Follow this advice, and the Mini Remote will offer you years of rock-solid performance.
Some extra advice is just buy 10 mini remotes from aliexpress and carry all 10 with you every time you go to the toilet or make love. Cheap, works every time and if you smash it you just pull another one out.
Nah, that’s not necessary. You will need to get some mace though as a mandatory Mini Remote accessory, because you will need something to keep all the girls at bay once you become the esk8 hunk in all their fantasies.
This is the correct orientation
This is not the correct orientation
Its 2019, stop judging :slight_smile:
