+1 for mini remote survived lots of abuse with minimal degredation in performance.
Mini remote is my jam
The mini remote is solid. The avio mod makes it even better
Mini remote for the win!!! Never had an issue with signal loss and VERY much prefer trigger control vs thumbwheels
Both the VX1 and Nano remotes are cheap and decent. They are NOT race quality though. If you want a race quality and dependable remote the Hoyt Puck is the least expensive option as well as arguably the best option. I mean, most people spend 1500 to 2500 bucks on a build, is 130 bucks really out of the question?
adding: i tried to pair nano transmitter with flysky receiver - but no luck. well it did get paired, but signal weak as hell, max 10cm range. i did even changed an antennas, any combinations its not working for me.
You need to set up the antennas length (exposed unshielded part of the wire) based on the frequency wave length of the transmitter. I have no idea what it is but that’s what you’d need to adjust to get it to work.
Also I agree with @mmaner here. I’ve used the wand, vx2, Puck nano and the mini and in terms of best overall the Puck is just awesom. There is no fancy screens or anything but it feels the best and is super rust too. The Vx1 comes in second if you want something a little cheaper that still works great though.
Hoyt Puck is inexpensive. Shit gets expensive when you crash and break body and/or components due to your remote. That won’t happen with the Puck.
Minis have been reliable for me, very cheap. If you need one near the UK I could send you one for very cheap but may be as cheap to get one from eBay or Ali.
Vx1 gives you the option to buy it for vesc 4, vesc 6, and non vesc… Which would be the unity?
One more vote for the mini. Lots of mods available.
The only con for it is the power switch plastic nub will break after a few hundred uses even if you’re careful. If you can swap the switch to a more reliable one, it’s perfect.
It’s not even the fact it will break, it’s just the fact it’s so fucking poorly placed you’ll accidentally hit it on and make your board do dumb things when talking to random street girls
where? i haven’t found them that cheap.
What is “race” quality?
Any difference between those and normal remotes?
Or it’s just advertising, like those “performance” fuel we could find in the gas station.
When you are going fast it works without fail. If you fall on it, it still works without fail. If you drop in your glass of metamucil, it still works, ask @BillGordon .
I still use a nano v2 on all my boards. Never had a drop.
Ebay 6 months ago
another vote for VX1 $40 shipped and has speed modes and battery indicator!
unlike the rest of these guys, i’m no good as a skater. an old man who got a board to commute, never skated before, not athletic, no core stability and ankle strength. as a result i go down hard more often than i’d like.
i don’t know where you at but healthcare is really expensive here in the united states, especially on my wage.
hoyt puck is the cheapest radio system for my use case. i hope you don’t have to use your radio transmitter as a slide puck like i do.
