When you use a PWM servo control, often called “PPM”, you need to calibrate the pulsewidths.
The way I do it is manually — I feel it works slightly better than the automatic approach.
I’ve covered both here.
Make sure you pair/bind the remote first. ![]()
works aight
turn off the remote and make sure the throttle stays within the deadband area
(if not, redo the failsafe setting)
works very well
Ideally, you want to be able to operate it from around -104%-ish to +104%-ish
with the center well within your deadband ( -0.1% and 7.0% below) even when you turn off the remote.
why’s that?
That way if you want to maintain full throttle for extended periods of time you can relax your hand instead of keeping the mechanism crammed into the end stop. You can just keep it lightly pushed and not have the jitters as it flips back and forth between 99.5% and 100%. It’s effectively like a deadband, but for the ends of the throw instead of the middle.
