How to make an XT90 Loop Key
Arguably, the most reliable way to control power to an ESC [pair] is to use an XT90S loopkey.
It may not be the prettiest or the shiniest or the most foolproof, but it probably will outlast almost any other way if done correctly, and it’s certainly the cheapest. This does have antispark characteristics if you use the “XT90S” instead of the “XT90” variant of the female connector. You definitely don’t want to use the female XT90.
Essentially, you make “a key” that you plug into the skate to turn it on. You pull it out to turn it off. Mount the male side on the skate and use the female side for the key.
finished loopkeys
A female XT90S showing the extra band. There is a 5.6Ω resistor inside, between the two bands on the left side. This functions to precharge the filter capacitors in the few milliseconds only one of the bands is connected while you push the plug in, preventing a mighty spark.
Items needed:
  1. XT90S female connector (best to have more than one)
  2. XT90 male connector (best to have more than one)
  3. MG Chemicals urethane conformal coating in 55ml brush-on bottle
  4. 6mm (0.25") tinned copper braid
  5. Sn60/Pb40 1.0mm solder
  6. soldering iron (I use the Weller WESD51)
  7. nylon string, 1.5mm diameter
This is something I was making for a skate a long time ago and made a wiring mistake, so I remade it instead of fixing this one. I use it to hold plugs while I solder them
What to do:
  1. Plug the female into a male (to hold the pins straight while it’s hot)
  2. cut three pieces of braid, tin the ends, and carefully balance them on the pins of the female
  3. carefully solder them on the pins, being careful not to knock them off
  4. wait until the parts cool before unplugging it
  5. {optional} I like filing it smooth to make it prettier. Don’t take more off than needed.
  6. Put one coat of sealant on it. Wait until dry. Repeat 25 more times until very thick.
  7. tie a loop of string on it so you can use it to remove the key after riding
When you use the loop key, make sure you push the plug in ALL THE WAY every time you use it. If it’s only partially plugged and you ride around on it, you will burn up the resistor inside the key, requiring you to make another one. Also, that’s one of the multiple reasons to mount the male side to the board (making a key from the female side).
or
example with lights/accessories circuit:
this way if there is a battery issue, your lights will turn off – consider this a warning from the BMS to pull over and pull the loopkey as soon as it’s safe to do so! :wink: (but it’s not gonna cut your brakes)
example without lights/accessories circuit:
use the above diagram, but omit the lights
For mounting the male part on your board, see the sister thread
Loopkey mounting. How do you do it?
Diy anti spark switch?
Tackling the anti-spark problem (Title by a good friend)
XT90S Loopkey sparking when inserted
Single vesc wanted
Can I BYPASS My BMS DISCHARGE?
[Serious] How To Solder | Soldering Guide | The Complete Tutorial From A>Z
Known Issues with Products
Beach Rding Without Destroying The Board
FocBox Tenka Talk
Trying to build my first esk8 for cheap.At the sametime, High quality.
The typical flux motion build
Fully waterproofing board [SERIOUS]
i think i have an obsession now
Some New FOCers (84V VESC 6 based controllers)
I dont live in the US, I dont have 1000+$, BUT I WANNA RACE!
Watertight button for Vesc
Incase of fire?????
How to make a XT90 Loop key
Best wire type?
Smoke. Melted/blown fuse on antispark switch. What happened here?
First Build, $1500 limit, suggestions!?
Cell Phone Charger?
The Green One | 29.6" Powell-Peralta | TB110 | dual 6355 | Caliber 2 | 10S 14500mAh [serious]
The "Why Can't" Thread
Right as I finished the build I broke the anti-spark switch
How do you secure your loopkey?
Charge Only BMS wiring advice
First build! | New to esk8 | Parts check
Glossary of Terms
Archived: the OG noob question thread! :grinning:
Cheap FOCer! (VESC compatible 4.12 redesign) (Tested and Functional)
Evolve Gen 1 Revive (parts help)
Pink Puma, first ever build. 10s4p, flipsky 4.2, dual 170kv motors
FOC_KING - 84V 150A, open source vesc6 board V2.0.1. JLCPCB order
Charger question
The cheapest mosfet anti spark switch build ever, hopefully
are these sensor cables that came with my vesc?
Discharge via BMS or Bypass BMS? [SRO]
Stormcore esc won't take any of my XT90 connecters?
How do I add this power switch to my esc
Can I Stack BMSs?
Wiring Schematic Help
Flipsky FSESC troubleshooting
Xt90s male or female from battery?
ChortL | 29.75" John Grigley | 3WD | TB130 | BN145 | 10S | 100 cells [SRO]
Intermittent voltage drop on 12s to <32V (possible short?)
There are other ways to make this work, but I now prefer the lower-profile versions.​
Linky for the braided copper? I’m currently using 14awg wire on all of my loopkeys.
This is good for 41A continuous, similar to 12AWG extra-stranded wire
https://smile.amazon.com/Tinned-Copper-Braid-Bright-Length/dp/B003HGHQYM/ref=sr_1_3
@whaddys you asked the other day about loopkeys. Here ya go dude.
Is there a reason to use the braid rather than 12 or 10 AWG? (asking not critiquing)
Might be much simpler to solder
Awesome Brian @b264
I usually take a piece of solid copper wire with 6mm diameter and bend it like a u.
Then solder it and put the amass isolation thingy without its core on top and fill it up with hotglue.
And yes, it’s dyed with the ritdye stuff :blush:
An other reason to use the female part is that it would prevent you (or anyone else without a brain) to plug it into a battery XT90 connector (which also should be female), with likely nasty consequences.
@b264 we need more of this type of content these kinds of tutorials are whats giving me hope i can build an esk8 and not a bomb.
Nah. One of those keys in the photo is 5 times 14AWG solid copper – but making it sucked far more than making the other ones.
Simple 5 ply maple handle handcarved
With 8awg wire closing the circuit
This was easy as hell compared to the stuff I make for clients XD
awesome, thanks @b264
would this be correct for a 10s2p li-ion and vesc?
Yes, that is correct. I usually put it on the negative lead, but either one works.
perfect, thanks!
Isn’t it safer, electrically speaking, to put a safety on the “hot” lead of a wiring rather than on the neutral?
Most BMS are wired with low side switching which means in most esk8 wiring, positive is not the “hot” side. It’s the shared connection between everything. Negative would be the “hot” side
Hot and neutral are concepts based on how the wiring is done. In most automobiles negative is neutral since it’s the common path (usually the frame) for the circuits. Electrons actually flow from negative to positive.
