This diagram is all I needed
Maybe you should add one to the first post @b264
@moon Done
Thanks @iespobolamas, I edited your image slightly and added it to the top post
Thanks I felt like you taught us how to solder it all but not how to wire it thanks
Awesome!
is there a reason some people use Anti Spark devices instead of a loop key? this seems way simpler and less likely to fail
Imo people chase the dream of perfectly watertight cases. Having a foolproof antispark with push to start inside the enclosure is a step closer to reaching that goal
thanks, so thereâs no functional difference in what they do?
Iâll stick with a loop key and some hot glue :)!
As to differences, @b264 aka âthe breaker of antisparksâ (yup I rebaptised you) would have more info as to why he keeps trying to have one that works
TL;DR there arenât really any âgoodâ options for that yet. Once there are, loopkey will be cheaper. Until then, loopkey is better and cheaper.
thanks Brian
I know âtraditionalâ switches are not used because of the spark. But do 90a rated toggle switches with a bleed resistor exist?
Pretty much a look key, but instead of ripping it out, its like a traditional switch. (More noob friendly i guess)
the only one I have found is here. It doesnât look incredibly robust and its still 30 bucks shipped, so I donât see an advantage over existing AS switches.
Check out @deckozâs as150 anti spark switch!
Trying to make a more compact loopkey,
any thoughts re encasing the bare joints in epoxy resin,
does it conduct at all once fully cured? or maybe just fill it all with hot glue?
Jb weld is your best shot
thanks, is JB weld not conductive?
the goal is to insulate + from -
I have no clue, summoning @b264
Yes. It can be conductive.
Liquid electrical tape and then resin just to be safe would be what I would do.
Be extremely careful with jbweld. Some variants contain actual metal powder in them (example:steelweld)
Epoxies are non conductive unless you specifically buy one that is used to be conductive (example: thermosetting epoxy for PC repairs)
Thanks @yelnats8j @Flasher!
Iâd never heard of liquid electrical tape, going for some of that then cast some resin in there.
