A list of all the active ESCs based on the VESC®
This is a WIKI so feel free to edit links/info.
All specifications are per side. No current rating standard exists so take all current ratings below with a grain of salt
The VESC measures current by using high side/phase shunts or low side/battery shunts. These design choices affect reliability and voltages.
Typically, 3 phase shunts > 3 low side shunts > 2 phase shunts > 2 low side shunts.
Based on VESC 4
Shunt Design: Two low side shunts
10s and 12s FOC / BLDC. First public release of the VESC. 60k eRPM limit. Known for a possibility of frying DRV8302 chips when using 12s FOC.
| HW4.xx ESCs | S/D | V | Cont | Peak | Forum | Notes | F/W |
| Cheap Focer 1 | Single | 12s | 30A | 50A | - | Open Source SW | |
| Flipsky FSESC 4.12 | Single | 10/12s | 50A | 240A | - | ||
| Flipsky FSESC 4.20 | Dual | 10/12s | 50A | 150A | - | ||
| MakerX GO-FOC Retro | Single | 10/12s | 50A | - | Forum | ||
| MakerX GO-FOC DV4 | Dual | 10/12s | 60A | 100A | Forum | ||
| Maytech MTVESC50A 4.12 | Single | 10/12s | 50A | 240A | - | ||
| Maytech MTSPF7.5K | Single | 10/12s | 100A | 280A | - | ||
| Turnigy SK8 V2 60A | Single | 12s | 60A | 120A | |||
| Turnigy SK8 V2 60A x2 | Dual | 12s | 60A | 120A | Forum |
Single MCU twin power stage VESC Branch
Shunt design for the Unity/Xenith: Two low side shunts
Shunt design for the Stormcores: Three low side shunts
After the V4 controllers were released, a lot of various projects were spawned trying to design a controller that could use 12s on FOC and not blow up. Jeffrey Friesen @Deodand and Charles Allix @Blasto worked with Enertion to design the FocBox Unity. It is a single MCU dual controller with 2 low side shunts that could reliably run FOC on 12s using the V6 DRV8301 and DRV8303 gate drivers. This controller was a huge improvement in terms of reliability and thermal performance when compared to the original V4 hardware… but it wasn’t perfect. The built in anti-spark system was known for failing and they would still blow up from time to time.
After Enertion went out of business, they partnered with Lacroix and using the knowledge learned from the Unity’s successes and failures, went on to design a new controller called the Stormcore. It featured 3 low side shunts, a robust anti-spark system, and higher voltage options using the improved DRV8323RS and DRV8353RS gate drivers.
One unique feature of these designs is that they can run a parallel firmware often called “super single” mode and use both sides to drive one motor, doubling the amp output. Other dual ESCs that use dual MCUs are not capable of this.
The FocBox Tenka is a Unity with half the fets removed and fully potted.
The BKB Xenith is the same as the FocBox Unity, but made by BKB using the original Unity design files. Minor noted improvements were a more robust internal anti-spark switch and more heatsink mass.
| Single MCU dual drive ESCs | S/D | V | Cont | Peak | Forum | Notes | F/W |
| BKB Xenith | Dual | 12s | 80A | 150A | Forum | Same as FocBox Unity | |
| FocBox Unity | Dual | 12s | 80A | 150A | - | ||
| FocBox Tenka | Dual | 12s | 70A | - | - | Removed half the fets & encased in epoxy | |
| Stormcore 60D | Dual | 12s | 80A | - | - | Built in Bluetooth, anti-spark and IMU | |
| Stormcore 100D | Dual | 18s | 80A | - | Forum | Built in Bluetooth, anti-spark and IMU |
VESC 6 based designs (using 60 series FW)
Shunt Design: Three phase shunts
12s FOC/BLDC. 150k eRPM limit. DRV8301 based design. Generally more reliable than VESC 4 designs, and not known for DRV chip failures.
| HW 6 ESCs | S/D | V | Cont | Peak | Forum | Notes | F/W |
| Boundmotor X-Core Pro | Dual | 12s | 100A | - | - | MakerX DV6 Rebrand | |
| Cheap Focer 2 | Single | 12s | 35A | 70A | Open Source HW | ||
| EOVAN Generation II ESC | Dual | 12s | - | - | |||
| Flipsky FESC 6.6 & 6.7 | Single | 12s | 60A | 150A | |||
| Flipsky FESC 6.6 & 6.7 | Dual | 12s | 100A | 400A | |||
| FRC ESC | Single | 12s | 80A | 150A | Forum | ||
| Flux ESC | Single | 12s | 80A | 150A | |||
| MakerX GO-FOC DV6 | Dual | 12s | 100A | 120A | Forum | ||
| MakerX GO-FOC DV6 PRO | Dual | 12s | 120A | 180A | Forum | Higher current fets | Custom |
| MakerX GO-FOC SV6 | Single | 12s | 120A | - | |||
| MakerX Mini-FOC/Plus | Single | 12s | 50/80A | - | Forum | ||
| Maytech MTSPF6.6K | Single | 12s | 200A | 240A | |||
| Maytech SUPERFOC6.8 | Single | 12s | 50A | 240A | |||
| MBoards DUAL ESC 6.6 | Dual | 12s | 100A | - | - | Ant Rebrand | |
| Motion Spin | Single | 12s | 80A | 150A | Forum | Uses a unique DRV chip | |
| TorqueBoards Torque6 | Dual | 12s | 80A | 150A | Forum | ||
| Trampa VESC 6 MK5 | Single | 12s | 80A | 150A | - | ||
| Turnigy SK8 V2 80A | Single | 12s | 80A | 150A |
VESC 75/300 based or similar
16S-18S The design removed the DRV8301 chip which was limiting the VESC 6 to 60v. It has three phase shunts with independent gate drivers. Phase shunt designs provide very accurate current measuring, and all other things being equal, should improve reliability. It also provides a smoother acceleration from 0% to 100% speed.
| 75/300 based ESCs | S/D | V | Cont | Peak | Forum | Notes | F/W |
| A200S v2 | Single | 16s | 200A | - | 18 fet, designed for robots | ||
| BioX ESC | Dual | 16s | 125A | - | Ubox Rebrand EU | ||
| Cheap Focer 3 | Single | 16s | - | 120A | Open Source HW | ||
| Flipsky FSESC 75200 | Single | 16s | 200A | 300A | A200S v2 based | ||
| MakerX GO-FOC HI100 | Single | 16s | 100A | 200A | Small, 6 fet | ||
| MakerX GO-FOC HI200 | Single | 16s | 300A | 400A | Forum | A200S v2 based | |
| MakerX GO-FOC HV200 | Single | 21s* | 200A | 300A | Forum | A200S v2 based | |
| Maytech MTSPF7.12K | Single | 16s | 200A | 250A | |||
| Spintend UBox 75v Single | Single | 16s | 100A | 135A | Forum | Has IMU, for balance | |
| Spintend UBox v2 75v Dual | Dual | 16s | 100A | 135A | Forum | ubox v2 300a fw.zip (363.9 KB) | |
| Trampa VESC 75/300 | Single | 16s | 300A | 450A | 18 fet | ||
| Trampa VESC 6 75v | Single | 16s | 65A | 130A | Unreleased |
*Trying to validate 21s rating as the INA240A1 current sense amp can only handle 80v.
VESC 100/250 based or similar
Shunt Design: Three low side shunts
This design allows for very high voltages. Removed the DRV8301 chip which was limiting the VESC 6 to 60v. Generally these use independent gate drivers.
| 100/250 based ESCs | S/D | V | Cont | Peak | Forum | Notes | F/W |
| A50S v2.2 6s | Single | 6s | 35A | 50A | |||
| A50S v2.2 12s | Single | 12s | 25A | 40A | |||
| A200S v3 | Single | 18s | 100A (10 min) | 320A+ | Small, 18 fet, used for robots | ||
| A400S v2 | Single | 20s | 200A | 600A | Water cooled | ||
| ENNOID-ESC | Single | 20s | 125A | - | Forum | Bolt on connections | |
| Flipsky 75100 FOC | Single | 20s | 100A | 120A | Forum | eBike size | Custom |
| Flipsky 75100 Alu PCB | Single | 20s | 100A | 120A | esk8 size. Improved design | ||
| Flipsky 75100 Alu PCB Dual | Dual | 20s | 100A | 120A | esk8 size | ||
| HESC Micro | Single | 20s | 300A | ||||
| HESC Mini | Single | 24s | 700A | ||||
| HESC 120/600 | Single | 30s | 1000A | ||||
| HESC 2.0 | Single | 30s | 1000A | ||||
| Little Focer | Single | 20S | 75A | 120A | Forum | Has IMU for balance | |
| Luna Ludicrous v2 | Single | 20s | 100A | 150A | for BBSHD eBikes | Custom | |
| MakerX D60 | Dual | 13s | - | 160A | Forum | ||
| MakerX D75 | Dual | 16s | - | 120A | Forum | ||
| MakerX D100 | Dual | 21s | - | 100A | Forum | ||
| Maytech MTSESC7.5R | Single | 18s | 100A | 200A | - | ||
| Maytech MTSESC7.5HK | Single | 20s | 400A | 1000A | Water cooled | ||
| Maytech MTSESC7.5DU | Dual | ? | ? | ? | Unreleased | ||
| Raiden 7 | Single | 18s | 140A | 250A | Forum | Balance board style | |
| Spintend UBox v2 100v | Dual | 22s | 100A | 135A | - | - | - |
| Trampa VESC 100/250 | Single | 22s | 200A | 400A | - | 18 fet | |
| Trampa VESC HD60T | Dual | 12s | 75A | 100A | Forum | ||
| Tronic (RION) 250 | Single | 21s | 250A | 300A | - | IMU, BT | Custom |
| Tronic (RION) 400 | Single | 28s | 400A | IG | 400PA, 250BA, IMU, BT | Custom | |
| Tronic (RION) 750 | Single | 30s | 550A | 650A | - | 650PA, 350BA, IMU, BT | Custom |
| Other VESC-Tool compatible ESCs | S/D | V | Cont | Peak | Forum | Notes | F/W |
| BMESC BM60 | Dual | 12s | - | - | Forum | Unreleased | |
| SmartESC | Single | 12s | - | - | Forum | VESC Firmware for Xiaomi M365 / Ninebot G30 | |
| VESC 6 EDU | Single | 6s | - | 50A | Forum | Independent gate drivers |
TL;DR:
Non-VESC based ESCs used in ESK8s
|RC ESCs|S/D|V|Cont|Peak|Forum|Notes|
|Castle Designs Mamba XLX|Single|8s|150A|320A|Forum|Has brakes/logging|
Discontinued VESCs
List
| ESC | S/D | V | Cont | Peak | Forum | Notes | Version |
| Ant 6.6 Dual Plus | Dual | 12s | 100A | 200A | - | - | - |
| BalancePro V6.6+ Gold | Single | 12s | 120A | - | Forum | Upgraded FETs, IMU | V6 |
| ESK8 1.2 | Single | 10/12s | 60A | 240A | - | EU, Direct fet | V4 |
| enertion VESC-X 1.3 | Single | 12s | 50A | 80A | Forum | Direct Fet, 12s FOC | V4 |
| enertion FOCBOX 1.6 & 1.7 | Single | 12s | 50A | 80A | Forum | Direct Fet, 12s FOC | V4 |
| Turnigy SK8-ESC V4.12 | Single | 10s/12s | - | - | - | - | V4 |
| Turnigy SK8-ESC V6 | Single | 12s | 80A | 150A | Forum | ||
| VESC 6.2 | Single | 12s | 80A | - | - | Original Release | V6 |
| VESC 6.3 MK3 | Single | 12s | 80A | - | - | IMU added | V6 |
| VESC 6.4 MK4 | Single | 12s | 80A | - | - | V6 |
