Greetings, I’m from Italy and this is my first post here.
I’ve been lurking, collecting info and dreaming to build an off-road beast since years (from electric-skateboard.builders), and now, since I moved to the alps, the moment has come!
Requirements
- handle 20°/25° degree incline for some time (I don’t know how much Amp this equates in real life)
- have at least 20km range
So here are the options I’m considering for the parts. feel free to suggest otherwise:
Board
My height is 1,90m and my foot is 46 and weight 90kg, I want a deck that is flexible to help absorb terrain hostility ![]()
Nowadays Trampa makes the 9-73 BIGBOI(Y) 17ply quite expensive for 314,26€
I’m planing in the future to source decks from local snowboards manufactures but in the mean time I’m open to other options
Bindings
Never used for skateboarding, maybe I can use my snowboard bindings? Anyone did this before?
Are MBS F5 Ratchet Mountainboard Bindings any good? Other comfortable options?
Trucks
I’m tempted to choose boardnamics’s BN270 Precision Hanger mainly for easy compatibility with their gear drive and adjustable baseplate, and wide width 131€ (hanger) + adjustable baseplate (93€) + Bushing (outof stock) +… Otherwise:
MBS Matrix II ? (137€)
Vertigo? (154€)
Apex Air? (219€)
Wheels
please advice 8/9" ? MBS T2 Tyre? Trampa Mudplugger?
Motor
I’ve already own two ODrive 150kv motors + encoders. They’re double shafted and requires some mount trickery
I don’t know if I’ll find a suitable drivetrain to mount them and a VESC that will accept those encoders.
In any case I need to buy other two to make it 4WD
VESC
I’m not updated to the latest that came in the last 3 years, unfortunately I miss the Stewii’s batch for the ESCape back in the time.
I’ve seen a list here
Any recommendation for a VESC capable to deliver 100A+ in FOC mode? “Cheap” (I’ll need 4) also would be nice ![]()
I’ve read good things about Flipsky FESC 6.6 & 6.7
but quite expensive. Maybe I don’t need 100A if is 4WD
Transmission
I have to find a way to mount my motor (if feasible in some way). In any case I’m sold on the Geared Drive solutions.
However I only know Nowind’s e-toxx and boarddinamics
An idea is to mix belt in the front (less noisy and less need for strong torque) and Gear Drive in the back, to also keep cost down.
batteries
Choosing LI-ion over LIPO for range and safeness. Hence a 12S configuration is a must. I was thinking about 5P or 6P but I don’t know if it’ll fit. I haven’t chosen the external box yet, but inside I’ve decided to give the press fit N.E.S.E. modules a go.
As for batteries I’ve good reviews for the Molicel INR21700-P42A 4000mAh - 45A
Anyone here have tested them and can confirm they can at least deliver 20A continuous?
BMS
to be decided, I like APEX smart ones (but they are expensive 45€)
VAR
I’ll need a lot of other stuff like antispark (not needed with flipsky) power switch, remote, capacitor pack (good idea or not?)
looking forward to your advice
