While it looks like you’ve done your homework on the tripple shunt design. Do you have any tangible proof of the 200A? I wouldn’t want to real world test if it can handle it or not…
You have to offer those on https://efoil.builders/ too! If you can add water cooled heat sink and your esc turns out to be reliable, you have a winner!
If I didn’t just bought A200S, I would take your new esc for sure! I am so excited!
Big emphasis on the efoil application! A real competitive 75/300 alternative would be adopted like crazy over there.
if you make a suitable heatsink for this that allows it to be mounted in an enclosure in a water resistant maner then im deffo on board with these. If you get the heatsink right im going to buy a pair of the 100A ones
7-8 layers of conformal coating (419D) to waterproof it and drop a heatsink with tall ass fins through your enclosure so you can mount any esc on it using a thin thermal pad and foam.
