I sell these parts because of missing storage room, time and motivation for a custom e-bike build. I bought all of it about 3 years ago and they have been stored unused in my basement since then. The prices are about 50% of the cost when i bought them and are in general “OBO”. The parts will be listed in forum.esk8.news and endless-sphere.com marketplaces because of the mixed scope.
MXUS XF40 45H 3K Turbo 60V 3000W
- Winding: 21x3 = 3T
- Power: 3000 W at 60V
Price (EUR): 150
- Weight: 5.9 kg
- Width: 12cm
- Material: High strength steel
- Dropouts 135mm
- Battery-size max dimensions: 44.5cm x 11.5cm x 9cm
- Bike seat
- Max rider load 120kg
- Gears: freewheel or gear cassette (adjustable)
- IS brake mount point
- Rear suspension 190-240mm (adjustable)
- Wheels: max26” (up to 35cm radius)
- Seatpost: 31, 6 mm
- Headset: 1 ⅛” (adjustable)
Price (EUR): 200 (Spring excluded)
Price (EUR): 230 (Spring included)
- 650 LBS spring
- Weight 0.35 KG ( 0.77 Ib ) ,240 mm ( 9.45 inch )
- Adjustments Rebound / Preload
- Damper shaft Hard chromed shock Ø 12 mm ( 0.47 inch ) shaft.
- Dark hard-anodized AL-6061 shock body.
- Riding style AM / FR / DH
- Color Black
- Size Eye to Eye x Travel
- 240 × 68 mm ( 9.45 × 2.68 inch)
Price (EUR): 30
- Weight:2.2 KG ( 4.85 lb )
- Damping:3-system
- Travel: 160 mm
- Dimensions:26 / 27.5
- Adjustments:Rebound / Lock out / Adjust High Pressure
- Stanchion:35 mm / AL-7075
- Brake type:Disc brakes (left and right mounts)
- Down tube: 20 mm Axle x 110 mm.
- Features:Single spring / Inverted fork / 1 1/8" Steerer tube
- Crown:AL-6061
- Leg material:AL-6061
- Riding style:AM / FR
Price (EUR): 150
- Voltage: 100V maximum
- Current: 200A continuous, maximum 250A
Price (EUR): 100
BMS Bestech HCX-D596
- Model: Bestech HCX-D596V1LI20S60A-01
- Charging voltage: 84V
- Maximal continuous charging current: 30A
- Maximal continuous discharging current: 60A
- Note: 2 Units available
Price (EUR): 30
Documents
HCX-D596 2.pdf (642.5 KB)
- Voltage: 84V
- Ampere: 5A
Price (EUR): 20
