Stuff inside the Stooge Raceboard
Mamba Xlx by castle creations. $210.00
SSS 5694 800kv 60v 12kw $102.00
(SSS 56114 420kv)
4x lipo 10ah 30c 4s (2pac series, series packs in parallel) 580wh, 600a rated means you should have the 400a needed to push without sag on an 6ga buss.
Setup should see 26+miles on thane, 19+ on AT using a 40mph final drive with moderate riding.
Esc tunabity is fantastic. Reliability and brakes even better. ZERO esc failures with this setup, riding and racing over 2years.
Expect 135f esc temps with motors cool to the touch after miles of uphill hammering.
For Down Hill, Brakes are predictable, graph tunable and reliable. They will do everthing you ask out of them. Over E-rpm is a non issue.
I use the GT2B radio with a receiver on each esc. Any paralleled link gives a path to destroy the other in the event of a single fault.
No signal parallels.
