List of available ESC and data points. The table is too large to fit on screen w/o scrolling but is still helpful. a link to the google sheet is provided for easier viewing and filtering.
ESC and related definitions can be found in the Glossary of Terms under “ESC Configuration”
Available ESC Table
| Manufacturer | Name | Dims LxWxH (mm) | current_constant | current_peak | volt_range | connector_phase | connector_dc | sensor_support | motor_mode | input_controller | link_image | link_purchase | comments |
| Lacroix | Stormcore 60D | 70x126x24 | 80a | 100a/200a | 50.4V max | 4mm bullet | XT90 | Stormcore (electronic speed controller) – Lacroix Boards | |||||
| Lacroix | Stormcore 100D | 70x126x24 | 80a | 100a/200a | 84V max | 4mm bullet | XT90 | Stormcore (electronic speed controller) – Lacroix Boards | |||||
| Enertion | Focbox_v1.7 | 64x64x22 | 60a | 300a | 8-60v | 3.5mm bullet? | XT60 | unk | BLDC?, FOC | PPM, Analog, UART, USB, CAN-bus, I2C | NEW: FOCBOX | It's how you build the best electric vehicles | no longer in production | |
| Enertion | Unity | 64x117x19 | 80a/160a | 150a/300a | 8-60v | 3.5mm | XT60 | ||||||
| Flipsky | ESC_v4.x Single | ||||||||||||
| Flipsky | ESC_v6.x Dual | 78x78x20 | |||||||||||
| Torqueboards | ESC_v4.x Single | 40x120x20 | 50A | 240A | 8V to 60V | 5.5mm Bullet | XT90 | TORQUE6 ESC – DIY Electric Skateboard | |||||
| Torqueboards | Torque ESC V6.64 | 80x70 | 💪 TORQUE ESC V6.64 - High Mileage Immediate Testers | ||||||||||
| Trampa | VESC_6+ | 75x70x18 | 80a | 150a | 6-60v | 4mm bullet | XT90 | ABI, HALL, AS5047 | DC, BLDC, FOC (sinusoidal) | http://www.trampaboards.com/vesc-6-plus-benjamin-vedder-electronic-speed-controller-p-26762.html | |||
| Trampa | VESC_6_75/300 | 82x141x18 | 300a | 450a | 14-75v | 4mm bullet *9 | XT90 * 3 | ABI, HALL, AS5047 | DC, BLDC, FOC (sinusoidal) | http://www.trampaboards.com/single-vesc-75v-300a-in-cnc-t6-silicone-sealed-aluminum-box--the-most-powerful-vedder-electronic-speed-controller-ever-p-26284.html | Nautical, Robotic, Scientific, Industrial, EV, Weapons | ||
| Castle Designs | Mamba_XLX | 🏁 SRB Esc Approach 🏁 - #11 by MoeStooge | |||||||||||
| Freefly | Arc200 | 93x54x22.5 | 60a* | 200a* | 13.6 - 50.4v | 8mm Bullet | XT90 | Fully sensorless, digital hall sensors, PWM | Torque mode (EV), speed mode (Multirotor, requires advanced user tuning), angle/servo mode (experimental, requires advanced user tuning and high-resolution motor encoder) | 🔥 Freefly Arc200 | Max peak phase current: 200A, Continuous current with little to no heatsinking (hot-side facing upwards and unobstructed): 60A, Continuous current when bolted to a typical EV aluminum chassis: 100-150A, Continuous current with infinite aluminum heatsink or water cooling, and forced air cooling on phase wires: 200A | ||
| Maker-X | Dual_Drive_v4 | 76x60x18.5 | 40a/80a | 100a/200a | 8V - 60V | unk | unk | Maker-X Go-FOC DV4 (upgraded version) ----- Most Affordable Dual Drive ESC | http://www.ebmakers.com/ | ||||
| Maker-X | MINI_FOC | 50x50x10 | 30a | 100a | 8V - 60V | unk | unk | ABI, HALL, AS5047 | DC, BLDC, FOC (sinusoidal) | Maker-X Go-FOC DV4 (upgraded version) ----- Most Affordable Dual Drive ESC | http://www.ebmakers.com/ | ||
| Maker-X | MINI_FOC_PLUS | 60.5x50x12 | 50a | 100a | 8V - 60V | unk | unk | ABI, HALL | DC, BLDC, FOC (sinusoidal) | Maker-X Go-FOC DV4 (upgraded version) ----- Most Affordable Dual Drive ESC | http://www.ebmakers.com/ | ||
| Maker-X | OFFICIAL_VESC4 | unk | 50a | 150a | 8V - 60V | unk | unk | ABI, HALL, AS5047 | DC, BLDC, FOC (sinusoidal) | Maker-X Go-FOC DV4 (upgraded version) ----- Most Affordable Dual Drive ESC | http://www.ebmakers.com/ | ||
| Maker-X | VESC6_High_power | unk | 200a | 100v | unk | unk | unk | unk | |||||
| Suburban Marine | Wavebreaker | 114.3x53.34x27.94 | 100a | 60v | https://suburbanmarine.io/product/wavebreaker/ | ||||||||
| ESCape | Dual | 136.5x67.5x14.2 | FOC | [WTS] [US] dual ESCape [SOLD] | ESCape only dual enclosure - #43 by Silverline - General Discussion - Electric Skateboard Builders Forum | Learn How to Build your own E-board | one off no longer in production | |||||||
| ESCape | single | ESCape only dual enclosure - #43 by Silverline - General Discussion - Electric Skateboard Builders Forum | Learn How to Build your own E-board | one off no longer in production | ||||||||||
| shaman | FOCer | 45x101x | 15V to 84V | Some New FOCers (84V VESC 6 based controllers) | Some New FOCers (84V VESC 6 based controllers) - #4 by shaman | ||||||||
| neo | neoBox | 60x60x16.5 | 70a/ | 60v | *SCAM ALERT* neoBOX open source Focbox variant (HW 4 and HW6 Design) - #200 by Itsmedant | ||||||||
| neo | singularity? | 60x80 | |||||||||||
| neo | 20s thing pending release | ||||||||||||
| esk8.de | 1.2 controller | 68x72x20 | 60A | 240A | 8V - 60V | optional | xt60 | FOC | VESC V4.12 bestellen | VESC V4.12 bestellen | |||
| Ollin VESC | VESC 4.12 | 39x110x18 | 80A | 120A | 8v - 60v | FOC | Home | Ollin Board Company | Home | Ollin Board Company | |||||
| Axle | VESC | 5.5 mm bullet | XT60 | http://goaxle.com/ | Axle vesc thread - New Items For Sale - Electric Skateboard Builders Forum | Learn How to Build your own E-board | ||||||||
| Vanda | ESC 4.12 | 40x60 | 50A | 240A | 8V – 60V | n/a | n/a | FOC | Vanda Electronics Speed Controller/Motor Controller | Vanda Electronics Speed Controller/Motor Controller | |||
| Faraday Motion | VESC controller | Redirecting... | http://www.faradaymotion.com/shop/18-electronics/4-vesc-motor-controller/ | ||||||||||
| Hobbywing | ESC | ||||||||||||
| Miami Electric Boards | |||||||||||||
| Carvon | |||||||||||||
| Michobby | |||||||||||||
| E-Greenmotion | |||||||||||||
| Unik | |||||||||||||
| Protoboards | |||||||||||||
| Alien Power System | |||||||||||||
| Phoenix | |||||||||||||
| Scramboards |
Setting up ESC
How to: Ackmaniac ESC Tool
ESC Battery cutoff settings
Optimum Vesc settings?
Battery Amps, Motor Amps and Duty Cycle… Please Explain
The Definitive Guide to Metr App / Metr Pro
Vote for your favorite ESC
- Enertion FOCBOX V1.7
- Enertion Unity
- Flipsky Single
- Flipsky Dual
- Maker-X varient
- Trampa VESC 6
- Torqueboards V4.12
- Other
0 voters
