Pneumatic Wheel Compendium (Serious)
The Goal
I’m sure you’ve looked at a wheel and thought :
. . . What pulleys fit this wheel.
. . . What bearings does it take.
. . . What is the bolt hole spacing.
. . . is it compatible with . . . .
Most 3.75" Hubs can fit 7" 8" as well as
  • Trampa 6.5" tyres, TB 6" Tyres
  • Evolve 6"
  • TorqueBoards 6"
  • Metroboards 6"
2.8" Hubs fit 6x2" tyres exclusively (Bergmeisters and Sixshooters)
After my frustration trying to find some AT wheel related information, I decided there should be a central place where this information lives.
The goal here is to create a thread detailing all useful information about different AT wheels. This is a bit of an experiment but hopefully, it will result in an organized, curated and maintained list of available wheels with as much relevant information as users can provide.
If you have any information about a specific wheels dimensions, bearing size, bolt hole pattern or maybe even a CAD model please post it below and I will try and integrate them into this main post.
The List
Trampa
  • HYPA
    • Plastic (Nylon?) 6 spoke hub
    • Fits most 6.5" to 8" tyres.
    • 125G/per hub
    • Starting price 15£/per hub
    • Up to 75psi
  • SUPERSTAR
    • Plastic (Nylon?) hub with Anodised Aluminium spokes.
    • 179G/per hub
    • Starting price 25£/per hub
    • Up to 75psi
  • MEGASTAR
    • 6061 Aluminium Hubs with Aluminium spokes.
    • 292G/per hub
    • Starting price 50£/per hub
    • Unknown. Up to 75psi?
    • Fusion Model : Fusion
  • MEGASTAR DEEPDISH
    • Fits most 9" to 10" tires.
    • 392G/per hub
    • Starting price 60£/per hub
  • PRIMO 3-SPOKE
    • Single piece 3 Spoke Composite Hub
    • 300G/per hub
    • Up to 75psi
    • Note:
    • These are uncommonly used because of the odd screw placement (few pulleys/gear drive support or don’t work with these hubs
MBS
  • FIVESTAR
    • Nylon 5 Spoke Hub
    • Fits 9″ | 8″| 200x75 | 7" | 6.5’’ | 6.3’’ | Tires, po ?
    • 165G/per hub
    • Price 9£/per hub
    • Up to 50psi
  • ROCKSTAR II
    • Nylon 5 Spoke Hub
    • Fits 7" 8″ Tires
    • 180G/per hub
    • Starting Price 12£/per hub
    • Up to 80psi
  • ROCKSTAR PRO
    • CNC 6061-T6 aluminum 5 Spoke Hub
    • Fits 7" 8″ Tires
    • 195G/per hub
    • Starting Price 22£/per hub
    • Up to 80psi
  • Additional Info
    • MBS Fivestar, Rockstar 2 and Rockstar Pro hubs all seem to use the same bolt spacing which is a 5 hole bolt pattern with the bolts 40mm from the center axel.
    • MBS Fivestar, Rockstar 2, and Rockstar Pro hubs use a 6001 2rs type bearing.
Psychotiller
440380-11dbd015a6ca48b1a636fe8a020e736f_1024x1024%402x
TorqueBoards
  • TORQUE All Terrain Hub Wheel
    • Nylon 5 Spoke Hub
    • Fits any standard esk8 tire, 6-6.5" recommended due to gearing
    • ???G/per hub STILL NEEDED
    • Starting Price 15£/per hub
    • Up to 70psi
    • Bolt Pattern : STILL NEEDED
    • Bearing Type : 608 style bearings
    • Axle Compatability: 8mm axles
3DServisas
  • FatBoy Mini AT 3.75"
    • Made by @3DServisas.
    • Fits 6.5 to 8″ Tires
    • 290G/per hub
    • Starting Price 180£/per set of 4
    • Up to 80psi
    • Bolt Pattern : 5 drive bolts at 27mm radius. 5 Wheel bolts at 42mm bolt to bolt.
    • Bearing Type: 22x7mm bearings
    • Axle Compatability: 9.525 or 12mm axles
  • FatBoy Solid Core Hub 4.65"
    • CNC 6061-T6 aluminum 5 Spoke Hub for accuracy and rigidity for the harshest road or trail conditions
    • Fits 9" Tires Only
    • 490G/per hub
    • Starting Price 190£/per set of 4
    • Unknown. Up to 80psi?
    • Bolt Pattern : 42MM bolt to bolt
    • Bearing Type: 28x8mm bearings.
Bergmeister
  • All-Terrain Pneumatic Wheel
    • Precision CNC milled three-spoke hubs made by @haggyboard.timo.
      7 different colours to choose from, 147mm wheel diameter and 45mm width.
    • Fits 145x45″ Tires Only
    • 163G/per hub
    • Starting Price 133£/per set of 4
    • Up to 85psi
    • Bolt Pattern : 3 holes in 44mm diameter
    • Bearing Type: 608 type bearings
Ali-Express
1032718826
Kaly
Evolve
  • Evolve GT Hubs
    • Plastic (Nylon?) 5 spoke hub
    • Fits most 7" to 8" tires.
    • 218G/per hub
    • Starting price 70£/per set of 4
    • Up to 50psi
    • Bolt Pattern : 5 drive bolts at 2mm radius, M4x3.0 bolt. 5 Wheel bolts at 45mm bolt to bolt.
      See also tech diagram here.
TEMPLATE
  • Model
    • Material + @ Owner
    • Tire Compatability
    • Weight Of Single Hub Without Bearing
    • Price In £
    • Max PSI
    • Bearing Type
    • Bolt Pattern
    • Drive File
    • Other :
IMAGE GOES HERE
There are a few hubs not mentioned here like mbs twistar etc…
This is because there are so rarely used in E-sk8 because of their odd bolt pattern. Drives can be made for these hubs but this is very inconvenient.
I focused on the hubs here. not the tires. Some hubs like Bergmeisters have their own tires that go with them. Haggy hubs can support 75psi but their tires only 50psi so please be aware your tire may be the limiting factor of max psi.
good idea, should we move this to a wiki for easier collaboration?
linked to this page in the Glossary of Terms wiki
Can you throw Ali-Express 6X2 onto there?
Sure, you got a link to some information?
6 shooters, haggies, TB numies, UnTrampa’s
From bang good but essentially are aliexpress wheels.
Fits 3D printed pulleys and adapters by @mishrasubhransu
MBS fivestar, rockstar 2, and rockstar pro:
47mm bolt to bolt distance and 40mm axle to bolt distance on fivestar, rockstar 2, and rockstar pro.
5 bolt pattern so math…
6001 2rs bearing
Mbs Trispoke:
608 zz bearing
TB 160x50 Tires & Tubes should fit on MBS/Trampa/Evolve.
Metroboard 155mm looks interesting.
Quick Q are those metroboard hubs just
@dickyho also has pulleys for the 6x2 wheels.
@Venom121212 thanks for those measurements. This is super useful.
@annihil8ted or @mishrasubhransu so you have a link to those printed pulleys?
@torqueboards can you share what’s the bolt spacing on your torque hubs? It’s it the same as mbs?
I am on mobile at the moment but when I’m back at my pc tomorrow I will try and add all this to the list :slight_smile:
Nice. What program did you cad these in?
The metroboard hubs are the same as UnTrampa hubs, from the same manufacturer called Sumate.
They do, I did a dry fit just to see. They also fit Kaly wheels which are dimensionally the same as Trampa/MBS.
You mean metroboard right?
Yes, fat fingered it.
Just to clarify, you just mean outer dimensions and not bolt spacing right?
Yes, just the OD.
