The battery builders club
[CLOSED]
The battery builders club has been split off for a new start
Please continue in here:
Batteries are dangerous if not treated right. Nobody want to have a fire at home or lose a board due to a wrong battery design.
This thread should be a summary of clean safe battery packs as well as a place where you can come and ask questions all about how best to build your own pack. Feel free to upload pictures in progress and ask our opinion about the layout, weld quality or what ever you not sure is right done or not.
@moon if I remember right you had a punch of pictures from well made pack. Maybe you would like to post some of them?
Battery builders
Rounded nickel strip controversy
The battery builders club 2
DIY battery "Rearrange"?
My first build dickyho 6x2 Samsung 40t
[Wiki]Building a battery (SERIOUS)
Battery Basics for Beginners Wiki [Serious]
Cheapest way to get a 20 mile range battery
12s2p flat battery pack using 40T cells
DIY Battery - First time soldering
Battery building online course?
Trampa DIY build and experience
Battery Question: Is this corerct:
where to buy battery cells?
🦆 Duck Battery Systems - DIY Supply Webshop
New Battery Build: 12s5p Lishen LR2170LA
Battery Help Need :) | Overkill Commuter | 5kW |12S4P
Spectre| Hummie Deck| Haggy Drive System| 2x 6374 190kv| 12s?p| Bergmeister and pepe wheels
Upgrading esk8 battery.
Building own 10S2P for MEEPO Boards with P42s-Need Help!
Current Ampacity Question
Cheap FOCer 2 (Open-source, Low-cost, VESC 6 based ESC) (v0.9 Release. Beta testing ongoing)
How to to join cells together?
18650 battery?!
Hey mofos, check out these sick threads out ...
First time builder - Wiring Diagram
Vesc For 90Amp Battery?
Power Traverse - electric snowboard
Requesting some input on first build.
Xiaoxang smart bms reset?
What's the best Vesc for my first board?
Archived: the OG noob question thread! :grinning:
Another BMS question - Sorry
DIY for long distance offroad
MTB build suggestions, new here
Building A 12S4P battery Are these parts okay options?
Molicel P42A 20s8p
DIY Speedy Beast! Evolve GTX, Low RKP, P45B, TB 6374
Enclosure Wiring Diagram
Battery and electronics will fit in one?
Battery config plans
Summerboard SBX Supermod
How do I troubleshoot/repair this 12S3P Li-on pack?
N00b Questions & Pictures Only Topics changes
Need help on building
Nikkel qnd parts for battery build
Can I build a safe 12s10p 30q pack?
help with BMS and charging
Are xt90 connectors safe for over 100A?
I need help please
I need help please.
Build a battery pack, is 18650 a good choice?
Trying to build my first esk8 for cheap.At the sametime, High quality.
Making a safer battery
Battery Demolition Club (How to disassemble take apart a battery pack, dispose of cells)
Got my Li-Po batteries. How would I connect it in series?
Yeah I’ll upload some, did delete a few but got most of them here
What perfect timing! Im writing a comprehensive “how-to” of battery building As we speak!
Very much needed here. Looking forward to it!
What do we think about this assembly style? ABS cell holders, 10 awg current carriers, cell > steel > solder > copper joints
Pros:
  • Minimal risk of bridging p-packs
  • shields underside of battery
  • flexible (only when enclosure mounted)
  • hella cheap ($20 for 10s4p) (only requires soldering iron)
  • replaceable cells
  • tested up to 10A
Cons:
  • unknown amp capacity (tabs limit to maybe 20ish)
  • 37% larger footprint over cells (no wires)
  • only single stack
Notes:
  • holders can be cut to make a smaller holder
  • optimal configurations are 8s and 12s (6s, 7s, and 10s have leads come out an outer corner)
  • use 4 slot holders (less cost and footprint per cell)
Procedure:
  • buy holders, 10 awg, 22 awg, solder on eBay for $20ish
  • wait 2 weeks for shipping :triumph:
  • fold the pins away
  • tape holders for convenience
  • make an XT90 pigtail (it’s the perfect width for the middle)
  • strip sections of the 10 awg to match the tabs
  • solder 10 awg to the top of the tabs (heavily tin both sides)*
  • add more solder because it never hurts
  • all the typical balance lead stuff
  • insert your cells of choice
  • shrink wrap the whole thing (190mm wide)
  • drop it into your enclosure
*Work with the frame sideways so gravity doesn’t pull the solder over the contacts (it’s already a super tight fit)
These are my two battery packs made in this style (10s2p and 12s4p)
This is my planned structure for the guide, am i missing anything? Any input guys?
  1. Common terminology and fundamental ideas
    What is Series
    What is Parallel
    Cell Specifications (size, discharge, charge)
    Nominal voltage and charge/discharge practice
    Servicing your battery
  2. Is it worth it? Understanding the options
    Risk assessment
    Compression
    Lipo
    NESE
    Prebuilt
  3. Planning your pack
    Size and weight
    Discharge
    Layout
  4. Ordering cells
    Reputable sellers
  5. Sticking your cells together
    Silicone vs Hot glue
    Insulating using Fishpaper and Kapton
  6. Spot welding vs Soldering
    PCB’s
    Copper Braid
    Nickel braid
  7. Always use (battery) protection
    Discharge vs Charge-only
    Wiring a BMS
    Team spark or team antispark
EDIT: Gonna add balancing wires here (like preventing crossing)
  1. Connectors 101
    Genuine vs Knockoff
    What should be used
  2. Charging
    Fusing your Charge port
    Charge rate
Maybe water proofing?
And antisparks/loopkeys
Was thinking antisparks and loopkeys would be under conectors 101, but can easily make that under protection.
In terms of waterproofing, what can be done to our packs to make them more waterproof? Liquid electrical tape? MG compounds? Hailing @b264
I believe @hyperion2 makes water resistant batteries by sealing the entire pack in a special shrink wrap and @b264 recommends using MG acrylic conformal coating on the BMS (or at least that’s what he recommended me)
Looks good. Point 5 I would definitely add the good old plastic cell holder/spacer.
And @b264 for loop key build process
I’m going to dig through and see if I can find a few more.
The bend over taps for the balance wires are made all in the negative terminal?
Yes. Otherwise you risk a short?
Not necessarily, but if to connect them on the positive I would use some fischpaper on the corner as well. As you can see on your pack there is a tinny gap between the terminal fishpaper cover and the fischpaper which goes around the pack. This gap would be connected to the cell negative if the isolation tube gets damaged.
I mean if the balance tap would be over this corner for example
The balance tab isn’t there though. It’s 5 cells to the left. Same voltage but no risk of a short.59
What about cell level fusing?
Not something I’ve ever used. If anyone has a wealth of info on this then bring it on.
@akhlut @Chaka
They seem to know a lot about it
here is a little on it with PCB’s
Also one big thing is to always fuse your charge ports.
@b264
If anyone needs a fuse Ill send you 2 free of charge just PM me. ( 8 people Left ) (US Only)
7.5 amps
