Battery Connectors
Generally used internally to interconnect charge port to battery and battery to ESC.
Amass XT90
XT90 Info
| Product Name | Amass XT90 |
| Wire diameter range | 8AWG |
| Continuous current | 90A (Max current 100A) |
| Connector | DC |
| Pin Material | Brass Gold Plated |
| Voltage | ≥500V |
| Feature |
XT90-S (antispark)
XT90-S Info
Same as XT90, but has a resistor built in which gets bridges the gap first, allowing your ESC capacitors to slowly charge up (without a spark), which then gets bypassed once you plug the connector in deep enough. No spark is safe for your electronics, and doesn’t wear down the connector!
XT60
XT30U (current, replaced the XT30)
XT30 Info
XT30U is the upgraded version of original XT30
- The main difference is XT30U is lighter. There is no reason to choose the old version over the U version. Both XT30 and XT30U are compatible.
- Connector rated for 30 amps and can handle up to 60A bursts with no issue.
- Great for auxiliary stuff like connecting your charge port to BMS, running a buck converter for lights, etc.
- Almost as small as a JST connector, but can support far more current!
- Can be soldered to up to a 14 gauge wire!
XT30 (discontinued, replaced by XT30U)
Anderson Powerpoles
Anderson Powerpoles Info
Connectors
Assembly Instructions
Powerpole & SB Technical Data Sheets and Drawings
QS10
QS8-S (antispark)
QS8-S Info
- Rated for max 200 amps
AS120
AS120 Info
- Rated for 120A
- Has four extra pins
Charging Connectors
XLR3(3-pin)
XLR Info
- XLR can accept 14 AWG (1.6 mm or 0.063 in) wire with a current-carrying capacity of 15 amps.
- Large variety of port mounts and covers in waterproof, locking and hardened types.
- One of the current ebike standards.
- Generally more expensive than other connection types.
- Larger than DC jacks or two pin ports.
Higher quality XLR plugs, like the Neutrik XX brand (rated for 16 amps), are an excellent choice for higher current charging.
GX12-3P (12mm)
GX12-3P Info
- Common across light electric vehicles such as esk8 and electric scooters.
- Rated for 7 amps from quality suppliers
GX20-3P (20mm)
GX20-3P Info
- Rated Current : 15A
XT60E M
XT60E M Info
AMASS data sheet for XT60E-M.pdf (510.0 KB)
Xt90s and XT60s are also often used. Make sure not to mix it up with your loop key port!!! Always put a fuse in series with your charging port to avoid such disasters.
SP13(2 pin)
SP13 Info
- Rated for 13A
- Small enough to fit on single-stack enclosures
- Has a screw-on cap for waterproofness!
- Plastic, so easy to epoxy to the enclosure
Cnlinko M20(size) LP-20
Cnlinko M20 Info
The connector used on the lacroix board, rated for 20 amps, ip67 certified, corrosion resistant, internals of the connector are interchangeable, so of you buy a pair you can config which is female and male
They also produce connectors in the same manner for usb A and rj45 among others
Z624
powerCON TRUE1 TOP
RoPD® - Rosenberger Power Data Connectors
RoPD Info
- Magnets force the correct orientation and hold the connector together.
- Has two power lines and 4 signal lines, nominally for CANbus.
- The Rosenberger connector was one of the standards adopted by energybus as a battery plug.
- More expensive than other connection types.
- Magnets can attract metal object and debris.
- Proprietary standard.
Zeet ZTC3002
ZTC3002 Info
| Product Name | ZTC3002 2Pins~2+4Pins |
| Wire diameter range | 18AWG~12AWG |
| Continuous current | 30A (Max current 50A) |
| Connector | DC |
| Pin Material | Brass/Silver Plated/Gold Plated |
| Voltage | ≥500V |
| Feature | Flame retardant/preservative |
ZTC4011
ZTC4011 Info
| Product Name | ZTC4011 2Pins~2+7Pins |
| Wire diameter range | 12AWG~8AWG |
| Continuous current | 70A (Max current 80A) |
| Connector | DC |
| Pin Material | Brass/Silver Plated |
| Voltage | ≥600V |
Zeet ZTC4011
SAE Connector
SAE Connector Info
SAE Connector
DC5521 aka 5.5x2.1mm (up to 5A, but gets warm at 4A & 5A) (it’s possible to find models that support 7A and 8A but they are difficult to find, and very stiff to plug and unplug)
This type of female port is only rated up to 2A. I (@rusins) burned one with a 5A charger
But these ones are rated up to 5A:
5.5x2.5mm
In general, it’s easier to stick to DC55521 connectors. The standard 2.5mm connectors can not handle more current than a good 2.1mm connector. Both are capped to 5A officially.
This female port from electricboardsolutions claims to be rated for up to 4A.
Motor Specific Connectors
Generally used internally to interconnect the ESC to the Motor.
5.5mm bullet connectors (up to 120A)
Good for 120A. Great for big motors! Ideally paired with 10AWG.
Also useful for battery connections (if you know what you are doing).
4mm bullet connectors
MR60
MT60
MR30
MT30
HiGo L1019D
HiGo L1019D
Weipu SA/SF 20/28
Weipu SA/SF 20/28
EC5-3 aka 3mm bullets
L1019DM
Signal Connectors
HiGo (lights, breaks, throttles, and accessories)
HiGo Mini-B
JST (hall sensors and lipo balance cable)
JST-SM 2.5 mm pitch
JST-SM Info
- Current rating: 3 A AC/DC max.
- Voltage rating: 250 V AC/DC max.
- Temperature range: -25°C to +85°
eSM.pdf (435.6 KB)
JST-PH 2.0 mm pitch
JST-PH Info
ePH.pdf (898.2 KB)
JST-ZH 1.5 mm pitch
Please place additions here
Any additions are appreciated
That way you could tell just from the outside what battery the board has
