Not gonna lie – I’m tempted to try it, since having 1 charger for multiple boards would be kinda cool lol
If you want to use barrel connectors for charging (I use xt60/90 or aviation style)
I’d go with 5.5x2.5 on everything.
Re-terminate all chargers with xt60/90 - make dongle for board ports. The screw down 2.1/2.5 barrels are really convenient. Can have a few pigtailed xt charger plug ins, strip wire with teeth, and screw down terminal to charge a non-standard noob on the fly. Or just have a bundle of premade dongles…
I think maybe having a a single adapter from 2.1 to 2.5 would be the better option…
But I do like the pigtail idea, I might do something like that, thanks!
There’s also XT150 which is the non antispark version of the AS-150. XT150 is 6mm whereas the AS-150 is 7mm
But on group rides, you can be the G carrying xt60/90 to literally anything (make every common port - xt369, 2-4p aviation, etc) - really wouldn’t weigh much.
Dunno. I just think having a solid modular cord to disconnect from the brick makes things easier.
Just today when charging was done the charge head briefly touched my skin and it was pretty hot, like i could only hold onto it for a few seconds. Not sure why my 12s charger came with this head. It was a 5A charger. I should probably cut and solder a 2.5mm x 5.5mm charger head and vice versa for the charge port on the board.
Are you the guy who said he confessed to spending hours on end high in an effort to find the best connectors…
maybe I got a different guy
lol not me, found it in 5 minutes of searching yesterday 🤷
though high also
Find me a 6 pin locking waterproof cup terminal connector more compact than an M-12 or GX16
The first automotive connector that comes up under those terms on Amazon is honestly the closet thing but it’s just too large to be reasonable for sensors (and it’s a crimp connector). 2xmr30 is currently the best option.
In speaking of expensive connectors
We paid $75/pop for the circle locking connector in 16 pin. Shit was ridiculous.
how’s this
https://www.amazon.com/dp/B07JQ8Q4JG/
As it is the housing/strain relief is just way too chunky man. One is larger than both of my phase connections. Could possibly be hacked up and re-potted but I doubt it. Dual mr30’s take up sooo much less space haha. I just hate the idea of shit being split across two, especially for something as easy to make a slight mistake in rewiring like sensors.
Not joking about how much time I’ve spent. Think I’ve seen every single thing on Amazon that exists in plastic housing aviation/barrel form.
lol same here, don’t think there’s anything smaller 🤷
Juuust maybe these guys
https://m.alibaba.com/product/60234860747/micro-circular-connectors-m8-6-pin.html
M8 connectors are officially not specced for 6 pin but
China
What about those:
That’s fucking humongous dude. Once again, larger than both of my phase connections haha.
If it’s not smaller than a MR-60, it’s a no.
Than how about yato 6 pin superseal. But u gotta crimp’em
Already mentioned.
In short - they’re close. I really need to see them in person I guess. Videos make them look larger than two MR-60’s tho so I don’t have great hopes.
I feel like at that point, I’d just go JST-SM and individually pot the crimp entrances with liquid e tape in a small syringe. I don’t however trust the housing of it to keep water from entering and covering the female pins…
Either way, if I were settling, I’d settle on 2x mr-30 before hand.
I think there’s something really special about having rugged, waterproof connectors on your cans, both phase and sensor, outside of your enclosure. Break a magnet because you didn’t battle harden them? One minute or less swap out. Don’t have to open the internals.
Even using mr-60, if you plan on going thru serious puddles, a thin bead of something like liquid e-tape or butyl tape should go on the connector mating seam, and all grey push on housings completely potted via liquid e-tape in tiny syringe.
It’s highly autistic, but so fucking worth it. Plus, half of the hobby for me is building cool robust modular shit. I love modularity in every thing I do…
Hit me when you find something. Bookmarking this.
Uh, just found this page: https://www.higoconnector.com/products/collection/signal/K999K#title
were you looking at the mini f’s or the mini b’s?
What I would be interested in is this connector as it has 3 phase wires rated 45A and 7 sensors rated 2A. For me it would be perfect because Im running 35 motor max.
