The Avio MK2 Gear Drive
Introducing the new Avio MK2 Gear Drive, featuring Herringbone gears! We have redesigned the entire drive and improved it based on feedback from the original MK1 Gear Drive.
Reviews from the community so far:
Pricing Table:
- Prices listed below includes PayPal Charges and excludes Shipping. For shipping charges, refer to the table below.
| Package: | Item/s | Est. Shipping Weight (KG) | Price (NTD) | Price (USD) |
| A | 2WD MK2 Avio Drive | 1.76 | $13,300 | $439 |
| B | 2WD MK2 Avio Drive + Kahua Trucks | 3.74 | $17,200 | A + $129 |
| C | 2WD MK2 Avio Drive + Bergmeister Wheels | 3.85 | $17,500 | A + $139 |
| D | 2WD MK2 Avio Drive + Kahua Trucks + Bergmeister Wheels | 5.83 | $21,500 | A + $271 |
| Add-Ons: | Item/s | Est. Shipping Weight (KG) | Price (NTD) | Price (USD) |
| 1 | 2x Hybrid Adapter | 0.20 | $1,800 | $59 |
| 2 | 2x 15T Pinions | 0.10 | $1,600 | $54 |
| 3 | 2x Hybrid Adapter + 2x 15T Pinions | 0.30 | $3,000 | $99 |
| 4a | 2x 170kv 6374 Sensored Motors w/ vibration proof sensor adapter | 1.90 | $5,920 | $198 |
| 4b | 2x 190kv 6374 Sensored Motors w/ vibration proof sensor adapter | 1.90 | $5,920 | $198 |
| 5 | Optional: Opt for our free motor shaft chopping service with purchase of motors. | n/a | n/a | n/a |
Pictures:
Estimated Shipping Cost:
- Shipping costs listed are in USD.
- Kindly use the Est. Shipping Weight (KG) listed in the Pricing Table above to estimate what shipping to your country will be.
- Bundling / combined shipping options are available. PM @avx if you’d like to arrange this. Do note that bundled shipping can be significantly cheaper. (e.g. A bundle of 5 Package A’s shipped to USA will cost $106 as opposed to $195 when shipped individually.)
| Shipping Weight (KG) | USA | UK / Europe | Australia | Asia |
| 0 to 0.5 | $26 | $26 | $22 | $16 |
| 0.5 to 2 | $39 | $39 | $33 | $24 |
| 2 to 4 | $53 | $53 | $50 | $35 |
| 4 to 6 | $70 | $70 | $66 | $44 |
| 6 to 10 | $106 | $106 | $99 | $63 |
| More than 10 | PM to enquire | PM to enquire | PM to enquire | PM to enquire |
How to purchase?:
- Simply place an order for a set by filling out the order form here and shoot me a PM for us to send you an invoice!
Improvements:
Herringbone Gears - Experience just how quiet these are. There’s a video below depicting the difference in sound between straight-cut gears and herringbone gears.
30% Smaller - The entire gear drive has been shrunk by approximately 30%! It now fits in your jeans pocket, if you want to use it as a really dope wallet.
40% Lighter - Severe weight reductions compared to the MK1. (MK2 @ 441g) vs (MK1 @ 745g)
30% More Ground Clearance - Ground clearance has been improved from 24mm to 32mm. Yes, we’ve seen the scratches on the MK1 when off-roading and we were not happy about it.
Swappable Gear Ratios - We’ve been getting comments from speed demons that like to go FAST. We’ve yielded. The MK2 will now feature a 13:43 (1:3.31)ratio with swappable gear pinions in the future such as 12:43, 14:43 and 15:43 (now available). Pinions can be easily swapped by simply pulling the gear out by hand and plopping a new pinion in. NO more green loctite or any of that set-screw crap, these drives are self aligning and do not require anything other than a secured keyway on the motor shaft.
Carbon Steel pinions on POM Wheel Gears - We changed out the Aluminium Pinions with S45C Carbon Steel coated with Black Oxide, while keeping our white POM Wheel Gears! Far superior strength pinions that last will last you a lifetime!
Designed to fit both AT and Urethane wheels! - With the new redesigned gear drive, we can adapt it onto PU wheels! A hybrid adapter for both original ABEC and Kegel wheel cores can be bought as an add-on!
What’s New?
Uploading: Screenshot_20200303_104549.jpg…
MK2 vs MK1 Size Comparison:
What’s Included?
| Material | Component | Colour | Qty |
| AL6061-T6 | Motor Mount | Black | 2 |
| AL6061-T6 | Cover | Black | 2 |
| AL5052 | Sealing Plate | Black | 2 |
| S45C-Black Oxide | Herringbone Pinion 13T | Black | 2 |
| POM | Herringbone Wheel Gear 43T | White | 2 |
| POM | Wheel Adapter | Black | 2 |
| Nitrile Rubber | V-Ring | Black | 2 |
| SUS304 | M3x8mm Screw | Silver | 4 |
| SUS304 | M3x10mm Screw | Silver | 4 |
| SUS304 | M3x25mm Screw | Silver | 4 |
| 12.9 Grade Steel | M5x25mm Screw | Black | 6 |
| 12.9 Grade Steel | M8x25mm Set Screw | Black | 2 |
| 12.9 Grade Steel | M8x30mm Set Screw | Black | 4 |
| - | 6705zz Bearing | - | 2 |
| PLA | 3-DP Squaring Jig | - | 1 |
Designed for the Kahua Trucks:
- The Kahua truck is made for speed on any terrain! It is the combination of a forged and precision milled hanger with super strong 12mm diameter / 8mm stepped axles and a 50-degree baseplate.
- 340mm total truck width with axles made of extremely strong carbon steel.
- Tighten the 92A barrel bushings and your board will be stable for gnarly speed fun, loosen them and you can enjoy an intense carving session.
Designed for the Bergmeister Wheels:
- Precision CNC milled three-spoke hubs in 5 different colors to choose from. 150mm wheel diameter and 45mm width. Fits all standard longboard trucks with 8mm axles.
- The Bergmeister All-terrain tire is designed with a multi-arc profile, which means that the thread profile varies across the full tire profile. This design allows for better steering and providing substantially more traction than normal shaped tires of same diameter.
Latest Video Update!
Progress:
- We’re now in the Quality Control phase!
- You can now reserve a set here!
Estimated timeline:
Early Nov to Mid-Nov: Settle logistics/ Negotiate with vendorsMid Nov to Mid Dec: Manufacturing + Quality ControlMid Dec - Mid Jan: Delivery on-route!- Mid Jan: MK2 Drives In-Stock!
FAQ:
Q: Are there herringbone gears for those who have the MK1 who don’t want to swap to the MK2?
A: Yes. We currently have very limited stock of Alu-Alu and Alu-POM Herringbone gears. These will be a one-off and we will not be producing anymore of these gears for the MK1. As of year 2020, the herringbone MK1 gears have been sold out.
Q: Can the MK1 or MK2 be adapted onto caliber trucks or any other trucks?
A: Sorry, no. These are designed solely for the amazing Kahua Trucks. Get them, you won’t regret it.
Q: What wheel adapters does the MK2 Gear Drive come with?
A: It comes with the Bergmeister Wheel Adapter and will be sold as a set with the MK2 Gear Drive. Also you can opt to get a hybrid wheel adapter for kegel and abec-styled PU wheels!
Q: Are there any other gear options?
A: We offer 2 different pinions - 13T and 15T. That means you can opt for either or both ratios of 13:43 (1:3.31) or 15:43 (1:2.87)
Q: How do I get my hands on one?
A: Fill this form up and we will send you an invoice for one!
Q: Is @BillGordon a poop?
A: Yes. ![]()
Supporting 3D-Printed Files
Assembly Video
Assembly Animation
WATCH THE ASSEMBLY VIDEO FOR INSTRUCTIONS. THIS ANIMATION IS JUST TO GIVE YOU A BETTER UNDERSTANDING OF HOW IT ALL FITS.
