This is an attempt to make a wiki post that can be updated continuously by you the reader as a jumping off point for you or others looking into gear drives.
| vendor | product | gear ratios | notes |
| 3D Servisas | Finality AT Gear Drive | 2.57, 3.00, 4.00, 4.44, 5.00 | |
| 3D Servisas | Finality HD Gear Drive | 4.00, 4.44, 5.00 | |
| 3D Servisas | mini urethane drive v5 | 2.2, 2.4, 2.6 | helical, for fatboy hangar |
| 3D Servisas | FatBoy SS Mini | 1.3, 1.36, 1.4 | helical or straight cut for fatboy hangar |
| Apex | Jump Drive | 4.4, 5.5 | Very thin, quick release for wheels |
| Archer Boards | E-MTB Gear Drive | 3.9, 4.5, 5.3 | Pre-order now! |
| avX | Avio MK2 Gear Drive | 3.92 | Unobtainium |
| Bioboards | Helical Steel Drive all in one | 2.2, 2.6, 3, 3.5, 4 | |
| Boardnamics | M1-AT Drive | 3.95,4.60, 5.20 (also 3.82 special batch) | mb trucks, Luna 350s |
| Boardnamics | M1 Drive | 2.22, 2.78 | kegel/abec |
| Eovan | Eovan Gear Drive Set | 2.857 | Proprietary coupler to their wheel hub only |
| E-toxx | fill these in | ||
| Exway | Exway Ace Gear Drive | 4.75 | Only fits Exway precision AT wheel hub and truck hanger mounting pattern |
| Janux Esk8 | Gear Drive System | 2.33, 2.39, 2.44, 2.47, 2.50, 2.53, 2.56, 2.59, 2.63, 2.65, 2.69, 2.71, 2.75, 2.80, 2.81, 2.87, 2.88, 2.93, 3.00, 3.07 | |
| Kaly | Gear Drive System | 4.0 | Discontinued. These drives are only compatible with Kaly Hangers and will accordingly only function on chanel trucks. POM gear with a steel pinion |
| Lacroix | Falcon™ Gear Drives | 4.2 | Fits Lacroix Hypertrucks |
| Linnpower | V4.3 Gear Drive | 4.3 | Fits Meepo nylon / cyclone / tubeless wheel hub, Exway atlas wheel hub, or Evolve wheel hub |
| Moon e-skate | All Terrain Moon Drive Kit | 3.4, 3.6, 3.9, 4.3, 4.7, 5.2 | discontinued |
| Newbee | Helical 4GS | 3.45, 4.00, 5.00 | Fits MBS and trampa bolt pattern, quick release wheel system |
| Omniesk8 | Omni Esk8 Gear Drive Kit | 2.67 | Kegel / Abec / Proprietary coupler of their own wheel hub, only fits 3 hole hanger mount with diameter of 34.5mm |
| Propel | Gear Drive for Propel Endevor 2 | 5.33 | Oil submerged instead of greased. |
| Stooge Raceboards | open gear drive | 3.05, 3.55, 6.09, 6.70, 7.09, 7.80, … | a variety of third party mod 1.5 pinions available combined with the 67T or 78T spurs for many different gear ratios. |
Add more please
pls keep it alphabetical by vendor
