We are finally releasing our geardrive system used on Plutonium 2 and 2S for almost 2 years without any issues. Thanks to @moon for a lot of support doing this. Its also the latest version of his popular Moon Eros design we use to make our Rims.
Just the geardrives starts at just 270USD.
We have designed it so this should be a system that supports almost all streetwheels (as long as they are not to small) with both Abec and Kegel adapters. Wide range of Rims supported. So hopefully this will be the only gear system you need even if you rebuild or change board in future.
Rims supported: Moon Eros, Bioboards rims, Rockstar, Fivestar, Superstar, Phatlads and probebly more rims that use same hole pattern (but probably you need a different length on spacer for them)
Big range of gearing ratio: 1:2.2 , 1:2.6 , 1:3 , 1:3.5, 1:4
Designed together for both our Channel and RKP truck that both comes with a integrated motor plate mounting, so no need for a hanger adapter. But we wanted to support the popular Matrix 3 truck so Matrix 3 adapter is also possible. We are still working on the channel truck design so I recommend to wait to order if you want the Bioboards channel truck.
We recommend to order our hangers and baseplates with the great bushings made by @RipTideSports
And I believe we manage to make it to sell it for a competitive price.
Gearing ratio 1:2.2 - 1:3.5 shares the same wheel gear, just different motor pinions and are made in 4140 QPQ coated and chemical blackened steel in mod 1.5. 1:4 has a different wheel gear and its a mod 1 gear.
Made for motors with 10mm shaft and max shaft length 27mm and 44mm hole pattern. Hanger shaft is a 10mm steel shaft and comes in 2 length depending on the rims you will use and bearings for it is included with the kit.
A perfect motor for this kit is our version of the reacher 6495 motor: 6495 5400W Motor – Bioboards Eskate
RKP truck is also available both with our standard 43 and 49 baseplate but also our new 43/49 baseplates with integrated tunnel riser:
Assembly instructions can be downloaded here
We will also send 2 review kits to @Takachi14 and @hoytkid very soon so you can read their experience (just waiting on longer hanger shaft to arrive that supports their choise of rims) But it has already proven how well it works from 2 years of hard abuse from Plutonium riders without problems.
Shipping will start by the end of next week, but please check the shipping info in product description for some parts.
We are also happy to give you the best warranty on the market: 3 years, 5 years for the pinions included!
