Super simple question, if I’m experiencing slippage of my belts would my time be better spent finding higher quality belts or adding an idler?
I’d like to keep tensioning out of the discussion - I realize that it’s easy to tell me that I’m not tensioning correctly, and it may be true, but that’s not the question I want to address today.
For me, idlers were training wheels until I figured out how to tension properly. That said, they’re helpful in getting easy pulley/belt engagement. As long as your belts are HTD5, no need to look for better belts.
Without going into tensioning, which is king, I would say check the alignment very carefully. A belt that’s not aligned well can slip, as @taz mentioned.
Something else that can cause anywhere from minor to massive slipping in a perfectly aligned and tensioned belt, is broken cords. If your belt has broken cords inside, you will typically not see any indication of this by inspecting it (sometimes you can though) but it will just skip like crazy. In that case, failure is imminent anyway and you need to replace it before many more rides. If you check multiple belts, some new, and the skipping persists…
Then check when the skipping is happening. If the worst skipping is happening any other time besides during hard braking, then I don’t know what’s going on. That’s always when the worst skipping happens.
Alignment – the best way I’ve found to perfectly align belts is
get motor mount (without motor) snug on hanger, then loosen a tiny bit so it moves
install wheel and pulley with no speedring (washer) between the hanger and inner bearing.
push motor mount flush up against wheel pulley so they are touching each other
keep those held tightly together while you tighten motor mount clamps
make sure mount is flush against, and touching, the wheel pulley, and there is no gap or misalignment
finish tightening mount clamp all the way
make sure again that mount is flush against, and touching, the wheel pulley, and there is no gap or misalignment
when you’re all done, take the wheel and pulley back off, add a single 1mm speedring (washer) and just like that, the pulley will be perfectly aligned and 1mm away from the motor mount plate
if you need it further away when you are doing tensioning, then add more washers
And also make sure your pulleys are concentric and don’t wobble at all as @taz mentioned. That’s super important.
edit: was solved below, was using HTD-3M belts/pulleys instead of HTD-5M belts/pulleys
Thank you everyone for your responses - It sounds like you are all basically in agreement so after reading your posts and poking around a bit I think the problem is motor mount flex. These mounts are custom design, and they worked great for chain drive, but they have just a bit too much flex for belt drive
I’ll be redesigning the mounts rather than messing around with belts or ldlers.
However, on checking the belt is labeled HTD but not HTD5. Did I get the wrong kind of belt? This is the belt I’m using
Amazon has some but they won’t deliver until June 4-20th. Do you have any recommendations for vendors that might be able to ship more quickly? I need a 312 but it sounds like the standard is 320, so it sounds like a bit of idler is in my future anyway
That’s about a 4.4 ratio so you’d be looking for a motor pulley with around 15 teeth (15 is the general consensus on the smallest motor pulley that can be run without slippage) and a 66 tooth pulley.
I’m not sure what wheels you have so finding the wheel pulleys will probably be the hardest unless they are a common hub. Any motor pulley with the right size/shape bore for your motor shaft and setscrew or keyway will work. I recommend Torqueboards and BKB for those.
I found a 72 at SDP-SI but they are out of stock. that led me down the rabbit hole of trying to make my own 80T, which I can do, but it will take a long time and I don’t have the right material in stock, so more $$$.
Neither Torqueboards (DIYElectric) nor BuildKitBoards have 72T, but I’ll order a few of the drive pulleys in different tooth counts (15 - 18 as you guys recommend).
I’m running 6-shooters but I can modify any pulley, I just have to find one.
