So its 15:40 on long dicky mounts?
I’d just measure it. No risk of having useless belts you cant return.
compare to Hoyt / metro? I also want to try those belt tension system, but not sure which one is easiest to use. i fucking hate adjusting belt tension
PSSSSHT
That’s the name of game, despite efforts to avoid it.
If you don’t want that, run gears
YES, as do I
He slept with my wife and shaved my dog. Or was it the other way around?
yea man, i’ve read that many times each time im adjusting them belts, but i feel like i never have correct tension, or maybe i did it correctly but my brain tells me im wrong, so i do it again
just done it…it s305mm when the tape masure is pulled taut. how many extra mm should i add?
short dicky ho’s
I thought you said the center to center of 9cm
it’s 85mm, just measured (I dont have the AT Dicky mounts, just regular street ones)
Can’t, but a great deal in comparison. I set up my first set, rode for an hour, then came home and immediately bought another.
The Haggy makes it so fucking easy and solid.
That’s really weird, dicky mounts are 78mm plus or minus 2.5mm
What do they do that is so much better? I thought it was slots like the rest
What belt are you currently running?
It’s so messy doing it that way. Start at 10cm, not at the end of the tape, and subtract 10cm from final measurement.
My bad dicky mounts are 78 to 83mm, I’d get a 300mm or 305mm belt
im running 12mm x 294mm on 17T/36T. But ive just bought some 15T/40T and the belt is tight as a drum
