Hi
Looking for a little help setting up a unitly
I have
12s4p 30q
Dickyho 170 kv motors
I have set
Motor max 50
Motor current - 40
Absolute max
Battery max
Battery regen
Thanks
Hi
I have
12s4p 30q
I have set
Motor max 50
Motor current - 40
Absolute max
Battery max
Battery regen
Thanks
Motor max 50 - max rating on your motors. 60A is a good start, adjust from there. max power at lower speeds
Motor min/regen - 40 - max braking at low speed, must be negative
Absolute max - as high as it will let you set it, maybe 150A
Battery max - 4P 30Q is max 80A but depending on how it’s constructed, could be less. 60A is safer.
Battery min/regen - how hard do you want the brakes to hit at high speed? -22A to start. Do NOT enter a positive number here. More amperage is harder brakes at high speed.
Thanks
I have two on and off button s
One on the unitly and one on the bestech
Do I setup roll to start and turn. Off everything with bestech switch then push to start
Or can I disable one of the two switches
Make the BMS switch on all the time
Will that leave my battery on all the time
So bms would be on all the time
Not really; the ESC would have power all the time unless the battery was drained past a critically low amount, which is a good safeguard anyway.
You need to make sure your BMS is capable of the currents you need, though. Which BMS?
Bestech d596
You should be okay with that.
I didn’t know there were separate braking currents for high and low speeds- I always thought that “battery regen” was the maximum charge rate of the battery (1c of capacity, so a 5Ah Lipo must have regen set to -5). Do you happen to know how an esc decides which current to use/ what speeds or factors it switches by? And will the vescs default -60 regen damage batteries rated for significantly lower charge rates? Thanks in advance!
Typically the high regenerative charge rates achieved by smashing the brakes at a high speed will be so ephemeral that they won’t upset the cells.
If sustained, a charge rate that high could definitely be an issue. But once you start braking hard, you immediately begin losing the momentum that would be needed to sustain such hard braking.
I have a battery pack that is 60amp max continuous discharge and I have a dual drive system. My vesc clone is connected on CAN
BUS. Shouldd I set battery current max at around 30amp or 60amp? Becasue 30amp x2 is 60amp.
Depends on your ESC.
A lot of “dual” ESCs like Unity you’d set it at 60A and each side would draw only 30A.
A lot of the time on dual single ESCs, you’d halve each “battery” number but don’t halve the “motor” numbers. So that would be 30A.
Depends which ESCs.
I have 2 single fsesc 4.12.
halve the “battery min” and “battery max” and leave all other numbers same
@b264 And how it looks with vesc6 (flipsky 6.6 dual plus) ?
My battery is 12s4p (30q) 60 amps continuous.
I never personally used that one, maybe someone else knows.
So I had to change my set up I have 2 focbox with split ppm
I set
Motor 60
Max break 50
Maximum cu 150
Bat max 30
Bat max regen was at - 22 breaks where weak so do I go to - 15 or so to make the stronger
Depends which brakes.
If high-speed brakes are weak, lower battery min from -22 to -25 or something.
If low-speed brakes are weak, lower motor min from -50 to -60.
If your motor min is at 50 you will have big problems.
