VX1 remote potentiometer wire broke.
Today my board just didn’t work. Turns out the remote was stuck in full brake/reverse. when paired it was sending a full reverse signal to the vesc. when unpaired back to neutral. pairing a different remote worked as expected.
opened it up and observed the red wire to the potentiometer had just failed.
glad this didn’t fail this way while riding. it would have hard locked the brakes. and in current mode hard locked reverse.
shakes my confidence in this remote though.
I will resolder it. wondering if I should hot glue it as well though i’m somewhat hesitant to make that mess.
EDIT for first post summary:
I think @rich had a solid observation later in the thread that with the wires routed wrong the thumb wheel can bump into them and wiggle them around which IMO would most certainly lead to eventual failure.
The correct fix is to reroute the wires and use better wires with higher strand count and to glue them in place to keep them wiggling to break point.
That’s scary
I would put neutral-cure silicone on it, just a tiny dab
yikes
They probably stripped too mant of the strands when pulling the silicone off, re strip it and make sure none of the solder joints look skinny. Some more solder on all of them should wick through and secure them
What’s the reasoning for neutral-cure vs hot glue in this application?
I’ll follow this advice. I need to order some neutral cure silicone for battery building anyhow. got a favorite brand avail for fast ship in the US?
Natural cure because it won’t corrode electronic surfaces.
I don’t see why hot glue wouldn’t work here. But have always used silicone because it adheres better.
Looping the wire through a hole would be cool, Lazy and cheap design.
Silicone is easier to service if needed and it fills crevices easier in my experience. It’s also less messy
I pull tested the other wires, and they got moved around a bit while soldering
The red one broke off the pot in addition to the board.
The white one broke off the pot.
The black one broke off the board.
I decided to test the failure mode of each wire.
Losing the red one failed to full brake/reverse ( as shown above)
Losing the black one failed to neutral.
Losing the white one failed to about 20% positive throttle. ( weird) also lost my screen shot of that sorry.
I desoldered the white wire board side and tried to get a close look at it.
couldn’t get a good photo of it. but under a magnifying glass it looked like only 50% of the strands were in the joint and the rest were cut off likely during wire stripping. evidence supporting @ZachTetra’s guess. but might be outcome bias.
I did the tin the wire before stripping it trick!
I didn’t think it work this small. but it did. also I’d never done it before. The trick where you let solder wick in to the wire and then strip it. ( works with silicone wire). pulling out a perfect pretinned wire. felt so cool.
I’d link to where I found that trick in these forums but I can’t find the post that mentioned it.
GE Silicone 2+
Or
GE Silicone 2*
I’m a bit scared to contradict my dude, but as a matter of public service, I need to chime in. Hot glue is really easy to service. All you need is isopropyl and a qtip. Simply swab the blob liberally with the alcohol, wait 5 mins and peel it off. Get a glue gun that does 100w and you’ll be amazed at how good glue works. Not knocking the silicone, but for electronics and small bits, hot glue wins for me every time.
Silicone for reliability, hot glue for easy service IMO although silicone is definitely less messy then hot glue
Throw vx1 in bin, get a better remote. #fuckflipsky
what’s your remote of choice?
afaict opinion is everything sucks except mini and hoyt ?
I have four of these and a hoyt. I liked the feel of the vx1 better so far. but this was pretty sketch inside. I will want to check the others. I have a mini coming. but they are cheap as chips too… so are they really manufactured to better quality than flipsky?
I haven’t used the mini yet, but I have 2 builds planned to use the mini with. Will be using the thumb wheel conversion for them.
I love the hoyt puck, its been bulletproof for me, will be getting another to have as a backup just in case.
I like the gt2b with the chozen case, I have heard of a few issues lately with gt2bs, but the issues seem to be few and far between.
I am eagerly awaiting the OSRR from @DerelictRobot as well.
Oh Fuck. Now I have to open my Vx1 and check everything. just for peace of mind :confused:
I’m on almost the exact same trail… spent the day perving mini thumb mod remotes…
and then I remembered I fukked around a long time ago with one of Robots remote models… there’s a lot of room… I already know it feels good in the hand, so I’m going to look into modding this into a mini thumb remote…
mini should get here Tuesday, Wednesday or never…
Then:
There is this as well;
Hmmmmm
I dropped mine from 60cm in dirt and the same happened. 20km from home and 3km from the train station. Resoldered and all good.
Thanks for posting this, scary shit.
So it seems we have to battle harden remotes as well :crazy_face:
It’s the Kony 2012 of remotes…
