That’s cool but definitely thought you meant your ass, not the board’s lol. I wear a blinky light on my belt when I ride at night (and on my board too)
I’ll add that the light controller I used can be configured on a cell phone (any brand, even a flip phone) or a computer or tablet (any OS) using wifi. It’s nicer than I was expecting it to be, ngl.
Some words of advice: don’t overlook the detail that some LED strips are 5V and some are 12V. Use the 12V ones. Both the controller and strip need to be 12V versions.
When you say used, how did you apply it? I can’t tell if it was just brushed on and covered (is it really viscous to not just slide off?) or like poured in after it had been wrapped in film or what
This is a really great setup. Can the LED controller vary the brightness based on throttle position? Or does it only detect that the throttle/brake is active?
It has distinct modes for Moving, Braking, and Standby. The LED brightness can be adjusted, but not by throttle position. Some modes have a speed that can be set based on position, but again, not on throttle position. So in theory if you set up the strip lengthwise on your board, I think it’s possible to have the LEDs travel down the board at the same speed as the ground, but I haven’t tried it. It certainly seems that way, turning the motor by hand. But my strip doesn’t go down the length of the board, it goes across the back of it.
I have the Braking red flashes at full brightness (you can also control the blink speed) and the other modes at a lower brightness. (You certainly don’t need to use red flashing for brake mode, but it’s an option)
