A revival of the 3D Models Wiki Thread.
For now it’ll be an almost 1:1 copy with smaller changes to start with. We might need to comb through all files to rework and or archive them out of the wiki if they are just not used anymore
Please edit this wiki with your 3d Models
This is a community editable wiki of 3D models for electric skateboarding. This includes but is not limited to 3d printables and CNC files. The intent is to have a reference of useful models for the community to use when building esk8.
Discussions on 3d models can be found here: 3D printables for esk8
Requests for 3d models can be found here: 3D files / CAD request thread
3d printed enclosure thread can be found here: [Serious] 3D Printed Enclosure Thread
Random Esk8 related CAD files: Random CAD Dump
Important note: If you decide to edit the Wiki, make sure to have a backup of what you are adding in case someone else works on the Wiki. Discourse might throw you or the other person out and undo the work if someone saves the wiki while it is being worked on by someone else.
Template
Model Name
- Model Description
- Model File
@Credit
[images]
3D Models
Truck related
Razilian Precision DKP/TKP
Baseplate.step (72.1 KB)
Double King Pin ver 5.step (240.4 KB)
Hanger ver 2.step (257.0 KB)
Razillian TKP 220 Axle v10.step (566.6 KB)
Hanger ver 2 is the original hanger. Razillian TKP 220 is the new one.
by @Razillian
Surf Rodz RKP 200mm Press fit motor mounts
- Updated file to V12. Now symmetrical so no left right version. Also there was a small error in the previous version where the motor plate holes where 0.2mm off being concentric with the outer circle. This version has 0.05 more tolerance on the truck mounting surfaces for a less tight fit as the aluminum one was a bit too tight before
- Surf Rodz RKP 200mm Press fit motor mounts by studio-napkin - Thingiverse
@LR-designs
[images]
Evolve DKP Damper
- Evolve DKP Truck Damper
- Evolve DKP Damper by TheTesticlops - Thingiverse
@RedBaron
[images]
Pulleys
Esk8 Pulley - 39t, for Abec11, 97mm with integrated bearing. 15mm wide belt.
- This is an electric skateboard Pulley - 39t, for Abec11 97mm wheels with integrated bearing support. For use with HDTM5 Pitch 15mm wide belt.
- Esk8 Pulley - 39t, for Abec11, 97mm with integrated bearing. 15mm wide belt. by studio-napkin - Thingiverse
@LR-designs
[images]
39t Pulley for TB110 Really Big Wheels
- This is a 39t pulley for 15mm wide 5M belts to fit the first batch of TB100 wheels with the larger rear holes.
- 39t Pulley for TB110 Really Big Wheels by studio-napkin - Thingiverse
@LR-designs
[images]
60T pulley for the BERGMEISTER wheels and TB218 trucks
- This is the 60T pulley for Haggy remixed with a bearing in it, for Bergmeister AT wheels on TorqueBoard Trucks 218 mm
- 60T pulley for the BERGMEISTER wheels and TB218 trucks by Riako - Thingiverse
@Riako
[images]
Pulley for aliexpress 6X2 wheel
- option 1: print pulley and pulley adapter
option 2; print pulley adapter and use vex robotics versa pulley - pulley for aliexpress 6X2 wheel($18 each) by mishrasubhransu - Thingiverse
@mishrasubhransu
Trampa Hypa pulley 66T HTD 5M
- Pulley for Trampa Hypa wheel
- Trampa Hypa pulley 66T HTD 5M by PetrHomolka - Thingiverse
@BigBen
36T ABEC Wheel Pulley - Bolt-On
- Pulley for ABEC core wheels, fits all of them
ABEC 36T bolt-on pulley by Linesflag - Thingiverse
Abec 36T Pulley v3.stl (795.1 KB) -
@Linesflag
Loopkey and Connector related
Loop Key Riser W/ Charge port
- Super simple riser with a XT-90s holder and a charger port holder
On the buttom there is also a place for a charger port fuse. - Loop Key Riser W/ Charge port by Jayday12 - Thingiverse
@yelnats8j
Loop Key Thingy for XT90s
- This thing is used to make your loose XT90s key look nicely and being convenient to plug/unplug.
- Loop Key Thingy for XT90s by DSC101 - Thingiverse
@dani
Amass XT90E-M Panel Mount Connector
- Genuine Amass XT90 panel mount
- https://grabcad.com/library/amass-xt90e-m-panel-mount-connector-1
@sleepless
Amass MR60 Connector
- Genuine Amass MR60 connector
- https://grabcad.com/library/amass-mr60-1
@ducktaperules
Riser related
7% Finality angled riser slim
- 7% riser for the Finality drive Trucks slim
- Finality_Riser_7_Precent.step (42.9 KB)
- RiserFinalityThin7.stl (61.0 KB)
- @EreTroN
7% Finality angled riser thick
- 7% riser for the Finality drive Trucks thick
- Finality_Riser_7_Thicker.step (47.0 KB)
- RiserFinalityThick7.stl (115.3 KB)
@EreTroN
Longboard Riser
- Riser that allows the routing of the motor cables under the truck.
Height 6.5mm - Electric longboard riser by tazman00 - Thingiverse
@taz
[images]
11mm Riser for Loopkey
- Print two of these and sandwitch a xt90 loopkey between these two. Use lots of epoxy to hold it in place between the two parts. Canals for 10AWG wire.
- 11mm Riser for Loopkey by niuva - Thingiverse
@niuva
[images]
Freebord Binding Riser
- HOOK FREEBORD design only for aesthetic look.
- Freebord Binding Riser by SurferOfDirt - Thingiverse
@glyphiks
[images]
Longboard Angled Risers
- Angled risers for longboard trucks.
Three angles: 5, 7 and 10 deg.
Hummie Deck Xlite Cable Riser
- Riser for the Hummie Deck to accept an Xlite rear light.
- Hummie Deck Xlite Cable Riser by Mudders - Thingiverse
@Mudders
[images]
Skate Riser Lights
- These are risers with space inside to put LEDs, a battery, charging board, and switch that can be screwed in as a riser between the trucks and the board (albeit a big one)
- Skate Riser Lights by wafflejock - Thingiverse
@wafflejock
[images]
Surf Rodz RKP Riser and Angled risers
- This is risers and angled risers for Surf Rodz RKP
- Surf Rodz RKP Riser and Angled risers by studio-napkin - Thingiverse
@LR-designs
[images]
Battery cell related
18650 Shell (10S1P / 5S2P / 2S5P)
- Shell has canals for balance leads for cleaner wire management in your builds. Can be used as 10S, 5S2P or 2S5P.
- 18650 Shell (10S1P / 5S2P / 2S5P) by niuva - Thingiverse
@niuva
[images]
21700 6 Cell Holder (6P or 6S)
- Cell holder for 6S 21700 cells
- 21700 6 Cell Holder (6P or 6S) by niuva - Thingiverse
@niuva
[images]
18650 4p & 5p Jig
- This is a set of Jig’s for 18650 cells. It allows you to keep the cells even while gluing and/or welding.
- 18650 4p & 5p Jig by mmaner - Thingiverse
@mmaner
[images]
NESE based 18650 battery modules and add-ons
- I use 18650 battery in my skateboard and use the modules from www dot 18650.lt (www.18650.lt). Each modules consists of raised copper tabs and a box. I am posting some of my modification to the original box design. My design is a bit smaller and meant to require some soldering
- NESE based 18650 battery modules and add-ons. by mishrasubhransu - Thingiverse
@mishrasubhransu
[images]
Spot welding jig for 21700 cells
- Jig to hold 21700 cells for welding.
- Spot welding jig for 21700 cells by bigbenbrown - Thingiverse
@BigBen
Hoyt Puck related
Hoyt Thumbwheel
- step file for thumbwheel of Hoyt Puck
- Pucking Positions - #26 by JJHoyt
@JJHoyt
[images]
Hoyt Puck thumbwheel mod 1
- Mmaner version
- Pucking Positions - #45 by mmaner
@mmaner
[images]
Hoyt Puck thumbwheel mod 2
- Quinn Version
- Pucking Positions - #41 by Fosterqc
@Fosterqc
[images]
Bumper / Fender / Handle related
Rain fender for Surf Rodz RKP trucks - LRdesigns mounts
- This is a rain fender to prevent road all manor of gross road shizz from spraying up all over you.
They are designed to bolt to my hanger mounts found here. And to fit 97mm flywheel or equivalent clones. Or smaller wheels.
Small Bumper for FatBoy Nano Gearbox covers
- Small Bumper protection for FatBoy Nano Gear Drive Gearbox covers 1:2.6 (small version)
… not printed/tested yet … - Small Bumper for FatBoy Nano Gearbox covers by Riako - Thingiverse
@Riako
[images]
Haggyboard Motor mount Bumper for Haggy Drive kit
- Haggyboard Motor mount Bumper for Haggy Drive kit.
- Haggyboard Motor mount Bumper for Haggy Drive kit by Riako - Thingiverse
@Riako
[images]
Bumper Fender Cover for Haggyboard Street kit
- Fenders pulleys covers + motors protector + motor mounts bumpers
for Haggy Drive and Senior Pepe wheels (90 mm) - Bumper Fender Cover for Haggyboard Street kit by Riako - Thingiverse
@Riako
[images]
Wheel guards for electric skateboards
- A collection of wheel guards to be used with an electric skateboard.
- Wheel guards for electric skateboards by mishrasubhransu - Thingiverse
@mishrasubhransu
[images]
Electric skateboard trolley handle, wheel guard, pulley cover and motor guard
- The pulley cover and the spacer is for diyelectricskateboard dot com reverse mount. The spacer makes maintains 166mm distance between outer faces of the motor mount.
- electric skateboard trolley handle, wheel guard, pulley cover and motor guard by mishrasubhransu - Thingiverse
@mishrasubhransu
[images]
Haggyboard Motor mount alf-Bumper for Haggy Drive kit
- Haggyboard Motor mount alf-Bumper for Haggy Drive kit.
- Haggyboard Motor mount alf-Bumper for Haggy Drive kit by Riako - Thingiverse
@Riako
[images]
Deck enclosure related
Jet Spud esk8 Enclosure
- This is an enclosure for Jet Spud deck (fits reasonably well on the concave).
- Jet Spud esk8 Enclosure by DSC101 - Thingiverse
@dani
[images]
22" Pennyboard Enclosure
- 22" Pennyboard Enclosure
- 22" Pennyboard Enclosure by niuva - Thingiverse
@niuva
ESC related
Case older dual FSESC6.6 + Heatsink
- I recommend you to wait before to print it, this is not yet printed and tested.
But you could help me with any tips or recommendations - Case older dual FSESC6.6 + Heatsink by Riako - Thingiverse
@Riako
[images]
Flipsky Dual 6.6 Enclosure
- Flipsky Dual 6.6 Fsesc Enclosure, has room for xt90 loopkey, charge port, power button, small charge only bms, and MT60 slots for motor cables and sensors.
- Flipsky Dual 6.6 Enclosure by TheTesticlops - Thingiverse
@RedBaron
[images]
Trampa Dual Focbox Case
- VESC case I designed for my Trampa electric skateboard and seen in my video series on youtube “how to make an Electric Mountain Board”
- Trampa Dual Focbox Case by BigBrit - Thingiverse
@Lee_Wright
[images]
Case holder single FSESC6.6 + Heatsink hole
- Based on my “Case holder dual FSESC6.6 + Heatsink”
- Case holder single FSESC6.6 + Heatsink hole by Riako - Thingiverse
@Riako
[details=“Flipsky VX1 Remote Reciever Cover [ PPM&UART ]”]
- A Version for connecting via a PPM Cable has been added.
I quickly designed a Case for the Flipsky VX1 Remote Reciever because it does feel fairly fragile with its 90 degree angle. - Flipsky VX1 Remote Reciever Cover [ PPM&UART ] by xsynatic - Thingiverse
@xsynatic
Flipsky VESC4 Trampa case
- This is a case for the V4 Flipsky for Trampa electric skateboards, It allows the heat sink to sit on the outside aiding cooling. Enjoy!
- Flipsky VESC4 Trampa case by BigBrit - Thingiverse
@Lee_Wright
[images]
Dual ESCape bracket and mounting bracket
- Dual ESCape bracket and mounting bracket
- Dual ESCape bracket and mounting bracket by Riako - Thingiverse
@Riako
[images]
MakerX DV6
- MakerX DV6
3D Models Wiki for Electric Skateboards -
@glyphiks
dv6 v1.step (655.4 KB)
MakerX DV4s
- MakerX DV4s
@BenjaminF
MakerX DV4s.f3d (1.5 MB)
MakerX DV4s v7.step (679.6 KB)
This is just a cosmetic model, I make no claims to dimensional accuracy. The total outer dimensions and the wire exits should be close (that’s what was important to my use, so I did my best to get these right) but the locations/dimensions of the heat sink fins, JST headers, etc, all came from overlaying a picture and sketching it out from there. I also didnt put in any screw holes or heatsink holes, because I dont think the holes on my unit (from an earlier batch) are representative of what is currently shipping.
Board storage related
Esk8 rack (you can hang your board vertically)
- 2 pieces for you to hang your esk8 or skateboard on front wheels… 1 piece for the charger mount… It can carry 22Kg + a cat of load !!!
- https://pinshape.com/items/53410-3d-printed-our-first-esk8-rack-you-can-hang-your-board-vertically
@thurbolt
E-TOXX Foldable Boardstand
- This is our E-TOXX Foldable Boardstand!
- E-TOXX Foldable Boardstand by E-TOXX - Thingiverse
@NoWind
[images]
Skate stand for Trampa Mini Truck
- This is a Trampa skate stand with Mini Trucks.
- https://www.thingiverse.com/thing:3009136
@KORINGER
[images]
10 inch wheel stand
Helmet Wall Hook
Gear Drive related
Lip for Nano Gear Drive 3Dservisas
- This is a lips for the Nano Gear Drive by 3DServisas.
You could set the Z scale to adjuts it to your needs
- https://www.thingiverse.com/thing:3437661
@Riako
[images]
Bergmeister adapter 3DSas Nano Gear Drive
- Haggyboard Bergmeister AT Wheels (145mm) adapter for 3DSas Nano Gear Drive
- https://www.thingiverse.com/thing:3650942
@Riako
[images]
Mountain Board Riser / Stomp Pads
MBS Warren Pro III Riser Pads STL to allow for underfoot cabling
Has channels for power leads for cleaner wire management in your builds.
Looks sexy AF
DWiii Riser Pad.stl (233.2 KB) -
Electronics accessories related
Pocket Voltmeter with Pass-Through port
- This allows you to plug into the cahrge port on your Esk8 (or wahtever) and see the voltage plus you can then plug your charger into the pass-through port to monitor charging.
- https://www.thingiverse.com/thing:3418423
@mmaner
[images]
eskate ibeams
- top plate for your board
- https://www.thingiverse.com/thing:3824353
@702vegas
[images]
DAVEga - Case - V12 - Vesc Monitor with 2 inch screen
- This is an early prototype case for VeGa battery monitor.
- https://www.thingiverse.com/thing:3171000
@LR-designs
[images]
Hub related
MBS Rockstar II Hubs
- Not sure who to credit for these but found them somewhere on here.
- Rockstar 2 Hubs.f3d (4.2 MB)
- Rockstar 2 Hubs.stl (2.8 MB)
Rockstar 2 Hubs.stp (2.0 MB)
MBS Rockstar II Pro XL Hub Wideners
- Description and important info can be found here
- Files:
- mbs_wide_20.step (75.4 KB)
- mbs_wide_10.stl (143.3 KB)
- mbs_wide_15.stl (171.6 KB)
- mbs_wide_20.stl (178.1 KB)
- mbs_wide_25.stl (200.4 KB)
- mbs_wide_30.stl (206.8 KB)
- mbs_wide_35.stl (224.9 KB)
- mbs_wide_40.stl (231.3 KB)
@Dinnye
uncategorized…yet
Dickosaurus Rex
- @BillGordon will explain it to you when you are older
- https://forum.esk8.news/t/reply-to-pictures-and-nothing-else-thread/81/7361?u=wandagoner
@Linny @DerelictRobot
Drilling guide - Haggyboard Bergmeister wheels pattern
- Drilling guide for Haggyboard Bergmeister wheels, here used for a 36T sprocket iso 06B.
Enjoy! - https://www.thingiverse.com/thing:3345373
@Riako
Turnigy Tx case holder (eMTB/eSk8)
Fishhook remote
- mini remote mod to make it thumb controlled and much more ergonomic
- https://www.thingiverse.com/thing:3363745
@dani
[images]
Bindings for esk8
- Bindings for esk8. We are still looking for a name:
- https://www.thingiverse.com/thing:3619398
@dani
[images]
Skateboard foot stop
- Print ready footstop for electric skateboards
- https://grabcad.com/library/skateboard-foot-stop-1
@bonesaw
[images]
Psychotiller 6 Shooter Offset (7mm)
- This is a 7mm offset for Psychotiller 6 Shooter wheels (
https://psychotiller.com/products/6-billet-wheel-hubs
). I sits between the pulley and the hub, its purpose is to stop belt rub on the wheel. This model replaces the extra pulley piece that is usually flipped to offset the pulley. - https://www.thingiverse.com/thing:3685050
@mmaner
[images]
Bergmeister Haggyboard chain adapter
- This is an adapter for Bergmeister Haggyboard AT wheels to work with chain on Evolve Supercarve trucks.
- https://www.thingiverse.com/thing:3372838
@Riako
eLOFTY Genuine ABEC Adaptor
- This is an ABEC11 adaptor for the eLOFTY Direct Drive
This will allow you to fit genuine ABEC 11 Wheels to your eLOFTY Direct Drives. These will not fit clone ABEC cores such as MBS, Slick Rev, Lazyrollers etc. - https://www.thingiverse.com/thing:3729092
@Lee_Wright
63XX Size Esk8 motor holder
- If you have 63XX size outrunner Esk8 motors and want to test their performance by mounting on a horizontal surface, you can use this thing.
*https://www.thingiverse.com/thing:3729056 -
@thurbolt
Evolve skateboard belt cover stand GT 97mm
- Replacement belt cover for the Evolve GT skateboards which also provides a flat surface so you can stand the skateboard on it’s end.
- https://www.thingiverse.com/thing:2521535
@mrg999
[images]
Change Log
27JAN2022 - Added category
02FEB2022 - Added Finality riser 2x
10MAR2022 - Added hub category, added MBS Rockstar II Models
