3D files / CAD request thread
This thread is meant for anyone to ask for specific CAD files and for anyone to post them. It is similar to one I created on the builder’s forum.
Creating this thread to be separate from 3D printables for esk8 so that it remains a list of final 3D printables without being cluttered with requests and back-and-forth conversation about it.
As long as i am able to edit this first post, I’ll try to compile a list of files under various categories.
Completes:
Trucks:
Decks:
Enclosures:
Battery Packs:
Placeholder for something
Does anyone have CAD files for MBS trucks?
Cronins please, or at the the very least a motor mount :slight_smile:
Anyone have a cad file for a press fit Kegel pulley that will fit popocas?
I can give you the CAD file of the wheel adapter part
So the part that presses into the wheel but not the pulley/teeth?
yeah 10cccccc
I PMD you my email Thanks
Made a folder,will update as I get some more things made
So far there is:
  • Venom Mach 1 - Cobra Core Wheel Adapter (making some of these now)
Venom%20Wheel
  • Kegel Wheel Adapter - with bearing seats that fit a 630 bearing - tried and tested
  • Focbox unity and focbox heatsink (making some of these now)
  • Surf Rodz MK16 Universal Press Fits
  • Motor Plates with a 46mm bolt pattern ( I think this should be the standard)
Anyone have a file for a kegel wheel?
https://grabcad.com/library/orangatang-kegel-80mm-80a-orange-longboard-wheel-1
Perfect just what I was looking for thanks!
Did anyone cad up the flipsky esc? or even unity?
Edit: to answer my own question: yes. https://www.thingiverse.com/thing:3495341
Theres a unity one too
@ducktaperules has made one.
@moon I don’t think you designed it to be this way but if you make the bearing seat only 2mm and you use a f608 bearing with a extended spacer you could have your press fit design fit on cal 2 trucks without modification!
Had no idea, thats pretty cool
This was the original purpose, the wheel bearing and wheel adapter share a bearing
Yeah it’s pretty cool that diameter of the hole perfectly fits the bearing! I think I’m going to have a set cnc’d now that it all fits perfectly when printed!
I had it CNC’d too no issues
