What’s the size of the tap? M3?
Yes 10ccccc
Do you know if the core is exactly the same on orangutang kegels and Popocas.
Make the shafts longer, like 20mm and it will fit for both
I can’t comment on that sorry
Does anyone know where to find 3D models of the vearious trucks used by builders besides caliber II’s. I am looking for any and all trucks so if you know where to find them, please let me know. Any help is greatly appreciated.
Do this
Sorry for the non-reply I guessed I missed this response, just came back to this because I will use your idea for the next time I make this
Recess the flange?
You recess the flag on the other side I’ll get back to you with some pics later.
i see thanks
@moon the inside thickness should be a total of 2mm.
It also needs an extended spacer to make up for the 2mm being used on the pulley.
We usually upload to any of the 3 places and share a link.
https://www.thingiverse.com/
https://grabcad.com/library
https://drive.google.com
BTW, welcome to this forum.
Dear Mishrasubhuanu, thank you very much.
https://www.thingiverse.com/thing:3712386
What do you guys use to make 3d models for your gears?
A little help would be great (I mean the drive pulleys not the wheel pulleys) cause I’m not familiar yet with making gears.
Btw what’s the best to reduce gears friction (less heat & less noise) wd40+silicon grease ? Silicon oil?
What kind of gears?
Remember when I stormed your IG with a weird variable AWD idea for my blades and I had no idea how to? Well I found the solution
So small pinion gears with fixed ratio to achieve 1:1 for every wheel driven, I can send you a sketch?
Yes do you have whatsapp, instagram is shitty
MP
10char
