These trucks are meant for different types of decks. If you have an idea of what type of deck you’re using, it’ll narrow this down significantly. For example, you can’t use hyper trucks on a longboard deck
Trucks and drivetrain matter so much though that I think it’s okay to start with that when doing a build, assuming you still plan the rest out before you buy anything
This is what I’m doing, thanks for that. Trying to not limit myself to a select amount of parts if I go one way vs the other (MTB vs Street style etc).
This is mostly because their decks have shallow angles of +30 up front and +25 in the back. And they use good urethane for their bushings. They definitely don’t actively prevent or correct speed wobbles, ask me how I know
If you really care about stability, go for channel trucks or RKPs, and do split angles and good bushings. Avoid PKP and DKP trucks.
To avoid the motors hitting the deck you end up choosing they have a different version of the mounts with the motors down lower. Then you can run pretty big motors on them.
I don’t know exactly how wide you’re going but @PropulsionBoards has some cool new trucks available - completely untested in our community but neat for sure
Ill take the cristicisim but I really enjoy the flipsky 15 inch trucks with the spherical bearing mod and tkp baseplate i went with them bc they were what i could aford.
