Long time gone without an buildthread from mine, showing in details what ya working with sometimes inspires others to go the same route.
Which is very nice as long you dont try to do this for living (-;
But i´m missing something … this spirit thing… away from comercial fuck off…, just posting pictures on instagram is poorly shit compared to in deep threads
coming back to good old days, showing what i passionated with, something new and innovating !
Worked on this since one year, i will not start with the History stuff, gone through at least 3 rideable Versions, thousends of FUSION360 hours, 3Dprinted and CNC machined tons of stuff ,got over 500 pictures from progress, could share this later if people are interrested.
Lets Start with what i have now, my Daily Driver , OBSESSED AF (((
after 6years of eMTB something which complete blowed my mind again
Whats innovating and was never showed before (as far as i know) :
DRIVEN TRUCK - like a UTV the complete AXLE works as “Hanger” and is driven through center chain
2-stage
FULL AIR SUSPENSION : NOT with crossdirection whishbones BUT with longitudinal direction whishbones - PROS : you need just 2 (not 4) and the complete steering principles stays the same
VERTICAL CHASSIS PLATES - 2MOTORS-4WD-LOCKED DIFF , just the consequences of it (-:
Pictures or it dont happened :
LOWEST POSITION - FULLY COMPRESSED
HIGHEST POSITION - FULLY EXPANDET
UNDERNEATH
FRONT / REAR
TILTED
ROCKSHOX
AMMO BOX (BATTERY AIRRIDE VESC GRAPHANDLE)
BINDINGS
CHASSIS SOLO
DIMENSIONS
OUTER SPURWIDTH 780MM
GROUNDCLEARENCE under TRUCK 110MM
GROUNDCLEARENCE under STANDS fully expandet 170MM
GROUNDCLEARENCE under STANDS fully COMPRESSED 55MM
GROUNDCLEARENCE in MIDDLE / DROP fully expandet 200MM
WHEELBASE FULLY EXPANDET 1020MM
READY TO ROCK
WHEIGHT 65KG
How it Rides :
Once you get used too absoltuely AMAZING
never felt that safe and planted on a board
wide spur and alot wheight helps
Due to locked Diffs / no diffs on both AXLES you have to work more then regulary to get her moving around corners , in special on concrete the massiv 11INCHERS needs to be kicked hard
Going ALL OVER, sand , rocks, deep in da woods , as long you have traction you are moving
SPECS :
Motors : 2 X QS2000W (10KG ONE)
ESC : VESC 75300 by Trampa
BATTERY : 16S-12P Samsung Q30
100MM Suspension TRAVEL
Topspeed around 40KMH
RANGE around 20km by average of 20kmh (average cruisung, no deep sand burnout stuff)
VIDEOS :
Running in Current Mode - 300AMPS on max Motorcurrent
Big Drifting
Small Drifting deep sand
it can be jumped
steering / Lean on concrete
Airride demo
Burnout slomo , @1.13 minute starts 4WD
uncutted average ride, example for the 20km range
many more online, YouTube : E-TOXX PSYCHOFRAME
Hope you like it, feel free to comment.
And of course this parts are for sale (-:
CHEERS
Jens
and an absolute massive unit man!
