Gday folks
If you have been following our account, you probably noticed our new truck.
We launched a pre-production batch a month ago to verify our Gen 3 design.
Now is my honor to launch the Gen4 design!
Price $180 per hanger
Link for more details & purchase
RTKP
Use code RTKP10 for 10% off (Current batch only)
Instruction:
RTKP is our patented design, it stands for reverse twin kingpin trucks, which included a master and a salve kingpin. Riders can place the bushing either in 2 or in 3 to satisfy different scenes. Carving, jumping, and Racing!!
Specs:
Hanger length 330mm
With the length of an axle 458mm
Weighted 800g including all the hardware
Full CNCed by 7075 Alloy
Riptide caliber pivot
22mm*22mm mounting shape
Design in detail:
Check out this video if you’d like to know this truck better.
https://youtu.be/C0mixjk_CfI
Riding Clips:
https://youtu.be/Sc2jSUCLk3Y
How to choose bushings (References only)
For matching the RTKP, You could also puchase our
Pro belt kit & 72t Pulley and DM1 rims
4GS(new version coming soon) & DM1 riims
Link here Completed drive kit
Gallery:
last two pictures from
@Adstars
Is there a different baseplate that allows these trucks to be used on a street board?
Been testing my set for a few weeks and I’m impressed, a great design.
Also, what deck is that? it’s beautiful
Well done, looking forward to making a second build with the new gears.
haven
May 11, 2023, 11:51pm
#6
Still shoulder bolts or axles now?
The full name is fine and all but since the design has nothing to do with TKP it seems a lil confusing. You could rearrange it to TRKP, but then it stands out a bit less here. Not sure which way to walk.
TKT twin kingpin trucks doesn’t seem bad but isn’t clear its a truck type like TKP RKP, PKP
Super cool, I wonder if @bboybowzer will buy some that I can try at carve lol
it almost happened but could still, batch 2 I hear is almost ready
It is the acronym of reverse twin kinpin…it still is rkp, tho. But twin kinpins.
As you can see, it is axle now…with chromed nuts.
lol, you know who made those sexy decks
We have the 45-degree baseplate design already, waiting some test fit…then i will make a batch.
tipsy
May 12, 2023, 8:32am
#16
Axles removable or epoxied?
Can still use shoulder bolts?
Can you list the difference?
rusins
May 12, 2023, 9:46am
#17
Just out of curiosity, what is the current baseplate angle?
Also, can people who bought gen3 purchase axles separately to use instead of the shoulder bolts?
You could still run shouler bolts, but you need to heat up the grub screws on the hanger, take the grub screw out first.
For the difference: Gen3 is 340mm hanger wide, axle spacer is 22mm wide, shoulder bolt axle. 960g per truck.
Gen4- hanger 330mm wide, axle spacer 16mm wide, using real axle with nuts, also added grub screw on secure the kinpin.
800g per truck.
tipsy
May 12, 2023, 11:22am
#19
Nice! 10mm narrower hanger is good.
Are the baseplates designed for tall bushings or normal on the board side?
Still hoping for lower degree baseplates, like 0 or 5
Will be getting just one for the front for now.
