It got buried in the messages above but it actually is an Evo build already. I had it wedged (to undo some of the dewedge) in the back because I have the motors rear mounted and couldn’t avoid ground clearance/interfering with the kingpin. I’m very slowly putting together my old shorter deck with narrower trucks, I can try split angles on that
Unfortunately the main one I use maxes at 60v, and the one I use for above 60v maxes at 3a.
You’re still going to put nylon locking nuts on those, right?
Yes, M6 lock nuts all around
60V is fine. Which is your main one?
It’s a Riden 6006. They have full kits on Banggood, and some other spots. They’ve also released a 12 amp and 18 amp model, but they require the appropriate AC power supply. But those are usually offered in kits as well.
Right, that’s one of the options I have considered. It seems a good value for money, though a little pricey for what I really need. I might get one regardless. Are you happy with it?
Dave Jones from EEVBlog is usually pretty murderous in reviews and he likes 'em, it’s how I saw them first (the 53 is just for the regulator module, not the bulk supply or case)
I do. Been using it literally every day for over a year. Made up a bunch of adapters and I charge almost everything with it.
I feel like all this should be in a “stability talk” thread.
that girl looks like my ex lmao
LOL…edited the post and embedded the table. No need to use Imgur now.
Markdown supports formatted text tables also.
Thanks!
Need to have it in a universally shareable format though as the table is posted in a lot of places.
If only they wouldn’t suck on mobile
test table
| Label | Multiplier | Quantity |
| Wheels | 121.99 | 4 |
| Motors | 154.89 | 3 |
Hmm. Not sure what you mean. Looks great… ?
3 work fine, but more or more of a hassle.
