Help. My esk8 is trying to kill me. Been riding my board on and off all day but this just started - Sporadically it will speed burst whenever I begin to apply the brakes. Scaring the shit out of me. I restore my Backup configuration which was fine earlier and it still does it. Remote issue maybe?
Not the wires. But check the solder on the potentiometer contact points. If it disconnects, it’s full zoom. You may be flexing it in the brake direction and it’s failing. They are known for having an insufficient connection.
You could reverse motors and puck direction to check if it’s still the same.
Yes. You can reverse remote direction on the remote. Forward will be brake and reverse will be acceleration. It wouldn’t stop it from going full acceleration though. It would just do it when you are already going to accelerate. I’m not convinced this is your issue so proceed with caution. Phase wire issues present in odd ways as well.
Well, I made it home intact. Only hit 42mph, honestly thought it would’ve been much faster.
At first glance it appears the potentiometer thing in the puck is OK. I put a couple of dots of hot glue to maybe prevent that issue if I can.
My dog is pissed at me so I gotta walk her before I check phase wires. I’ll be back in an hour or so when I get my board torn apart… hopefully with an explanation. Probably more questions lol
I peppered some sarcasm in there but I guess it doesn’t translate via text… I swore Id had enough after the last one. It put the fear in me. Took me some time until I could really get on the throttle again but I still don’t think I’ll ever be able to ride the same as I did before. Don’t think my knees will ever be the same either.
