TB110 Delam fix (hopefully)
For the record I don’t think this issue is widespread and this only happened to 1 of my wheels.
So after a few more rides with the issue getting a bit worse and more dirt getting in there I decided to clean it up and glue it.
I used a couple soldering tools like flat edge screwdrivers to wedge it and make enough space for a dental water pik to flush the cavity out.
I used orange degreaser for some time and scraped what I could out with the tool. And followed up flushing with the dental pick thoroughly. 90% prep work.
Then I dried the outside and let whatever drip out. This glue recommends wetting the surfaces so I didn’t wait too long to inject glue. I did this like I cleaned with the water pick, inserted the glue nozzle between the wedges I jammed in and pressed in decently hard with the nozzle. I could see the glue flow into the cavity in every spot, very satisfying so hopefully this works well. I just wiped everything off with a towel after removing the flat edge tools and especially brushed the kegel holes with a straw brush.
Unfortunately no pictures of the glue application since that stresses me on it’s own. Hopefully this description can help out.
Here they are filled with glue: (good for testing tomorrow)
:+1: Watching; I had some delam problems with some TB130 prototypes
I was thinking about drilling a hole from the edge of the core into the thane then gluing in a screw.
If this holds up long term then that might be a much better idea.
I thought about that too, but IDK
2 out of 4 on a set of blue TB110mm 72a had delamination issues.
If the wheels are black, you would not know if the wheels are delaminating. Scary.
The blue wheels after a few megameters are opaque as well.
I like that glue a lot, but I wonder if you could fill the delam with a two-part polyurethane instead of glue.
This has happened to me on 3 of 4 wheels now. I fear my wheels will explode due to my dodgey ‘fix’.
I fully support your decision.
did you put some glue into the hole drilled for the screws? I would just not want it to start splitting from the inside.
Yes I glued the screws in too. The other wheels I ‘repaired’ i used 4 screws and no pins. This example has 4 pins hammered in between core and wheel and two screws that go in diagonally from core to wheel.
I thought about this but I wanted something cheap, also that I could work with well to inject. The PU would have to go into some kind of applicator syringe. In my case most of the core is still holding so I’m more ok with something that isn’t a polymer.
Epoxy is probably better in a full delam like jeff, I would have removed the core to clean and coat it all with epoxy. Also not sure how good everything sticks to PU though.
I would def press that core out, I’m thinking it could be pressed back in nicely since the front tapers. I’d use a lot of glue and reassemble but cleanup of the kegel cores filled with glue sucks especially while its setting so maybe tape them off or something idk.
To me it seems fixable with the right glue and without reinforcement screws lol
Yikes, have all these been with 72As? How about the 74/78A?
That’s what I’m thinking. Just bought a set of 74a. Apparently the best big wheels around now I’m reading these :joy:.
So some small poke test and it delams again. Maybe riding tests will go better, I didn’t poke the other side. I’ll probably wait for full core separation, press it apart and epoxy it together. Anyone know what kind of plastic is the core made of?
I went ahead and filled that small spot, if nothing else this glue applies pretty well. :joy:
Delaying testing until a day or two now for this to dry
Honestly, the only glue I’ve found that actually sticks to post cured urethanes is cyanoacrylate. Even urebond or a few specific urethane adhesives I’ve had lack lustre results. :nerd_face:
Lol so good ol crazy glue. My concern with that is it dissolves the bonding surfaces including the exterior so you get a huge mess. Did you find it brittle or it created a good flexible bond?
Here is Gorilla clear msds
And Gorilla super glue msds:
I think it’s glass-filled nylon.
