this one is too cute i had to post
interesting, this would really be perfect for this design and so compact it would fit under a freebord no problem
And this is all a distraction because regular old springs are an adequate solution for sure.
I might be broke soon but have many a Efreeboards
I will bid up to $500 ish
hmm shit this is almost more related to Veiftech - DIY upgraded Leiftech V2 at the moment but at some point I’ll have to move to a thread about both SBX and V2 upgrades, prob once I have both versions with prototypes produced.
I am finally ordering these bits:
https://www.amazon.com/gp/product/B07SG84ZBL
https://www.amazon.com/gp/product/B014GXM3UG
That with some 3d printed test parts let me make this
oh yeah need to grab the kfl08 pillow bearings but given they are 608 bearings I can just make the seat in the test arms I print.
Would be good to move away from those sooner rather than later, ok for an early version I guess.
You could probably print a TPU pneumatic actuating suspension system for this application
Beryllium copper maybe, and maybe silver tungsten.
haha where were you before I figure that out myself a exactly 19 days ago lol
I hadn’t gotten back to this thread for a while LOL
I was way back in May, and still haven’t read the whole thread yet
This looks to be the cheapest way to get some of this stuff, and ships from 1 hour away from me.
They only have round but I bet it could be rolled into strip if need be.
I guess I wonder if round brush contacts are ok because they should be contacting at an angle and wearing away a rectangular surface larger than the diameter of the round material.
trying to figure out how to make slip ring, reverse engineer leif further
small motor controls the suspension so it can be lifted at will.
I think this idea, combined with an electronic brake on the rotation of the E-Caster as well as self balancing on the center caster would be a usable combo. What I imagine is you would be riding it like a freeboard but then you could get going straight on the center wheels then engage the rotation brake, at the same time the suspension lifts you and self balancing engages. if you are sliding when you start the lift system it will ride like an EUC and if going straight it would ride like a OW. Dumb idea to go too fast when doing this obviously.
oh yeah why the fuck have I not printed a pulley for the JMK ride wheel yet
3.5 inch (90mm) small brushless hub motor, 24-36V 250-350W, max load 100kg, max speed 10km/h. Motor weight:1.6kg.
took a min to find this
Bldc 4 Inch 24v 36v Walking Speed Gear Electric Hub Motor Wheel , Find Complete Details about Bldc 4 Inch 24v 36v Walking Speed Gear Electric Hub Motor Wheel,24v 36v Hub Motor,Dc Brushless Gear Electric Motor Wheel,6km/h Gear Hub Motor from Electric...
Price: USD 55
Etech 4.5 Inch 250w Wheel Hub Motor With Built-in Encoder , Find Complete Details about Etech 4.5 Inch 250w Wheel Hub Motor With Built-in Encoder,Dc Motor Optical Encoder,Encoder Motor,Brushless Motor With Encoder from Electric Bicycle Motor Supplier...
Price: USD 109
2020 New 3 Inch 12v/24v/36v Electric Small Gearless Hub Motor Dual Shaft Wheel , Find Complete Details about 2020 New 3 Inch 12v/24v/36v Electric Small Gearless Hub Motor Dual Shaft Wheel,70mm Hub Motor,E-scooter Motor Wheel,Dc Hub Motor Wheel from...
Price: USD 39
