Hit the bolt hard a few times until it moves slightly. Then put the bolt on the other side and hit it hard a few times until it moves. Then go back to the first hole and repeat. The pulley will eventually fall out. You have to hit it kind-of hard. (See how I smashed the bolthead? It’s not smashed in the first photo )
You would have to build an adapter, but I picked up one of these gear pullers from the local auto parts store for like $20. Put two bolts you whack with a hammer through an arm that sits on the center bolt. I’m not sure if you can see in the close up picture. I stuck the fuzzy side of some velcro inside the jaws to protect my fancy hubs from scratches. Any excuse is a good excuse to buy a new tool.
One of these days when I am feeling energetic I will write a primer on fatigue, shock loads, crack growth, and crack initiation. I’ve read some things that aren’t quite correct on the other site. Given the beating these boards take under our feet I’m probably oversensitive to the subject.
I honestly don’t understand how people put a thousand miles on a boosted. I feel like I would decimate one in a few weeks. I typically tear all of my boards down every 6 months or so just to make sure everything is good, I almost always find something to fix that is stress related.
my favorite on the facebook groups is “my esc in my wowgo/skatebolt/whatever else these shitty boards are being named stopped working how do I get it to work again because the company wont reply to my emails.” My response you buy a shitty board you get shitty service/quality.
