Fuse your charge ports: Ft. The smallest user serviceable fuse/holder
Fusing your charge ports is important. Fusing your mains leads is as well, but we’ll argue about that another day
I’d have to presume a large reason a lot of us aren’t/don’t want to fuse our ports (aside from not knowing about it/being a lazy fuck) is because of space constraints. Sure, you can solder directly to the fuse as @b264 does in his The Blue One build - but in the case of needing replacement, that’s a bit of a hassle.
After having found and used what I thought to be the smallest modular fuse holder in my own builds, thanks to @Jansen pulling out some tiny ass blade fuses I’d never seen before, I’ve found something even smaller (and finding the holders for these was actually fairly hard - there ain’t a lot of them made/sold)
So, here our are options.
Mini Blade Fuses/Inline Holders
For space constraints, I modify mine a bit.
Fuses specced from 7.5A-15A (depending on your charger needs) at 58V are perfect - but the 12V ones work just as well
Even smaller:
Low Profile Mini Blade Fuses/Inline holder
https://m.littelfuse.com/products/fuses/automotive-passenger-car/blade-fuses/891.aspx#
https://www.optifuse.com/inline-fuseholders-mini-low-auto.php
Actual purchasing:
https://www.hawkusa.com/manufacturers/opti/series-lps-01
https://www.brevan.com/opt/LPS-02B-18R
Fuses:
https://www.mouser.com/Circuit-Protection/Fuses/Automotive-Fuses/MINI-Low-Profile-Series/_/N-ba8b5
Pay no attention to the unconstrained wire clutter seen:
Fuse holder w/dual lock(both sides cause was drunk and derped orientation) that holds it down nicely.
Fuse it before ya lose it
Just curious, what about these?
€ 1,44 8% Off | 10PCS 5*20MM Glass Tube Fuse Holder Screw Type Quick Blow 5X20MM Fuse with 22 AWG Wire 250V
https://a.aliexpress.com/_UlN7z
Yup, that be a fuse holder.
Glass and tube style might not be the best thing for such a heavy vibration environment but that’s really just me guessing. I’d also be worried about it unscrewing, but loctite should fix that even tho it’s plastic.
Soldering an xt-30 to the low-profile minis is a great idea as well, but that gets into being proprietary.
I think it will hold. I mean those kind of fuses are used in all kinds of environments.
If there’s limited space are there any issues with using an external fuse between the charger and battery? (apart from it being something else to carry with the charger)
Then you are not protected from a short at the port (due to e.g. water)
Been using those for a year as well as in my friend’s boards, it still works/charges. I have never replaced the fuse. Not even once.
You shouldn’t be replacing fuses very often or at all. And if you do need to, you’ll be glad even if it’s difficult because the alternative is much worse :crazy_face:
I have only blown out one fuse and it’s because I did something really, really, dumb. Something we’re all bound to do if you ride enough.
Nobody ever said you have to replace a blown fuse. You can always just add another one.
Thanks!
Blade fuses not ideal, as they’re usually rated for 12v or 24v (arcing can maintain electrical continuity). I like Littelfuse Pico 2 series, I think the 60v version. They look like chubby resistors.
You can buy 58V blade fuses from just about anywhere.
https://www.mouser.com/ProductDetail/576-099707.5WXN
i got these… 10 pk for 5 bucks.
Oops sorry struck out my error. I remember not being able to find these. Sigh lol.
or say a dummy with a multi meter. ( not saying that was me or anything… but I melted a multimeter probe. )
They look awesome but I had a good look at the range and can’t find any options under like 200v
Lol, true that, I have used multimeters in sketch ways, too. Have been lucky though. Gotta always first ask yourself “what if I slip?”.
I woke up sweating at 5A.M. wondering about whether or not the fuse should be placed before or after BMS. Obviously, in picture, I have it on ch- of BMS. I have my theories on what should be done - but @professor_shartsis or somebody else, can you chime in?
In the thingiverse page I link to the fuse I used: https://www.arrow.com/en/products/0251007.mat1l/littelfuse
Here are some 10A ones, some not in the Pico series.
https://www.arrow.com/en/products/0251010.mat1l/littelfuse
https://www.arrow.com/en/products/0324010.hxp/littelfuse
https://www.arrow.com/en/products/0324010.mxp/littelfuse
I know they have high voltage ratings, but if I understand correctly, voltage ratings for fuses are for arc-breaking, so too high is fine, too low is bad. AC vs DC is very very important (AC self breaks the arc when it crosses zero volts).
I use this to hold the fuse, and allow bypass.
I’ve tested the 7a fuse to failure using a lab PSU. Nice!
This is nice. Stilll slightly proprietary, but small enough you could store a few spare in the enclosure so it doesn’t matter as much.
