I searched “daly BMS dimensions” and did not get what I wanted.
Boom thread just about daly BMS stuff
Specs, how to make your 16S into a 15S, dimensions, CAD files.
Sources:
USA:
@mboards
@BenjaminF
and more
China:
aliexpress
Sources:
USA:
@mboards
@BenjaminF
and more
China:
aliexpress
I don’t normally sell them, but I have some big boy 12S ones 80×60mm for when I need to be able to charge 8A+. I can ship immediately, but not trying to undercut, so same price as Kevin.
12S daly dimensions measurement
Bought a 10s from @A13XR3 the other day
Those are the sized up ones, with 12awg wires and such, not that commonly used.
The smaller ones most people use, that I also sell are:
Also this is the PCB of the 16S-12S board’s as you can see the entire PCB is populated but the final 4 are shorted together internally and the JST is swapped out to the corresponding S count.
[image] This is how they adjusted the 16S stock to 12S. And the IC say it’s suitable from 5-16. So I hope it actually works as intended.
Someone said Daly BMS??
Here are bunch of dimensions for liion version:
10s
Size: 9mm x 34mm x 59mm
13s
14s
15s (modified version of 16s)
Size: 9mm x 48mm x 75mm
20s
search phrase
daly bms size / daly bms dimensions
e: ping me if u need some other info, but these are most likely the ones that people should be interested about
e2: Daly has a habbit of “lying” about those dimensions, 9mm is the tinnest part of the casing, 11mm shoud be the accurate thickness when battery builders are checking for them dimensions
You da bomb, dude
always try to help out a fellow user if i can
anyone tried their smart bms?
any good?
I was just showing these new guys to @stratoglide the other day. They look like friggin GPUs now! You know you’re a special kind of nerd when you get excited about how a BMS looks…
Smarter Shopping, Better Living! Aliexpress.com
any good?
I made a pack with it and it’s not bad, sets up like every other BMS but they have lugs instead of pigtails
@tomiboi is the one who used it
how is the app and also the price makes it slightly cheap then an llt with what i believe is a smaller footprint in the 30a size
also is the 12s just a slightly adapted 20s?
as in if you buy 20s can you reasonably easily convert it to whatever voltage you like?
Sizzle-pants has endless power. Love the battery, but that BMS is a biggin’. Mine doesn’t have bluetooth.
no, 12s is a modify version of 16s, which require a different firmware also. same goes for 18s bms
ah k
assumed since they were all the same size
is it possible to buy 16s and convert them somehow?
since when same size = same product?
yes, there is a way, but why would u do that? a 12s or 16s bms isn’t even expensive to start with
same pic + same size + on same webpage thought it might be
cause that way you can just order 16s and then whatever is require convert to that rather then thinking what exact voltage you will use
convert to that
good luck contacting daly to get the firmware and also their software to flash the bms
Its just a settings file, not the entire whole software.
I asked LLT 12s to 10s settings file and they sent it without any issues.
So I guess it will be the same with daly
