Damn, its bigger than an esc ![]()
OK, Playing the role of a beginner again >.<!
I just got press fit inner bearing pulleys, and just figured out that my caliber 50 axles are 35mm i.e. too short. [I know of; file the truck, remove the bearing. But I want the bearing to be there.]
My question is: If I cheap out and only purchase one extended axle truck for the rear how badly would that effect board geometry?
ty for reading.
As long as you make sure you donāt get wheelbite on the narrower front truck you should be fine. Brian did it and I think Iāve seen others too, build thread here
Iām just going to put search terms here in case someoneās looking for it in future: mismatched truck mismatched hanger different hangers width
Yes, it would affect it. It will look worse but perform better. ![]()
Itās horrible I love it, Looks like a wedge of cheese, [jokes aside it does look OK, good in some abstract sense i.e. I think it looks good]
Thanks guys!
It also makes me itchy, but Iāve had the same thought. My poor filed down calibers wish Iād gone with that option, as does the hand file who suffered through it
I have never needed to make an account before but I finally have a question that I cant find an answer for anywhere. from what I understand @Gamer43 designed an antispark switch for flipsky. I have a few of them and have yet to have one fail. My question is: can you wire 1 momentary button to control 2 antispark circuits? My board is 4wd and it is thoroughly annoying to have to turn it on with 2 separate switches each time. Is it possible to use just 1 switch and create my own wire harness? or do I need both forever.
Yes, I do need 2 of them. I previously and foolishly tried just one and burnt it out rather quickly. 4wd 6384ās draw a considerable amount of current. who would have guessedā¦
I"m no EE, but I donāt see why not
Make sure they both have a good ground connection.
They are highside switching because I know what Iām doing so yes, you should be fine doing this.
so all 3 wires should be paralleled?
I prefer a narrower track at the front. Its more responsive and turns a lot better. Can def look pretty kooky tho.
Yeah, Now I realize itās a reduction of turn in the rear which is a good thing for stability I was just concerned it were the other way round.
only issue I see now is my instinctive driving on the bleeding edge which focuses on the front truck launching me into issues where the rear may catch onto the road to walkway lip ![]()
[when on pathways I like driving road side past obstacles like lampposts where wheels hang over like 10-20mm]
as someone with ~290mm total width, I am often afraid of this in general while riding
I hope thatās deck width not waist sizeā¦
outer wheel edge to outer wheel edge
Yeah youāre running 270s? oof
No, only the switch line, which is K+.
Make sure they have good connections to system ground.
Anyone used Earthwing wheels? I got a set of their Superballs Slide-B that are supposed to be stone ground slide wheels but they arrived with a noticeable glossy skin on them and they do not slide at allll
Anyone know a good xt90 loopkey mount that doesnāt require a large hole in the enclosure
One that runs parallel to the enclosure if possible
