Duuuuuuude. Way to research! Fucking excellent writeup bro, look forward to seeing this one come together.
I have recently ordered the SV6s for a build I am doing for a mate, I hope they can stand up to some punishment!
I’m planning a pneumatic tire build with the eLofty DD 58kv edition.
Bookmarked!
Huh, had never heard of the VTC5D cells. I wonder how they compare with 30Qs after a few dozen recharge cycles though…
Your build looks super promising! Switchblade + elofty + Janux bergmeister hubs seem like an amazing combo the acceleration doesn’t suffer too much.
Also, I had never heard about that site you bought your lights from. Let us know if they function properly; I have my doubts about smart lights like that working on bumpy roads.
Can’t wait to see this come together
N.E.S.E. modules fit can fit a 12s4p 18650 on my enclosure, I’m glad it did, I’ve been asked several times about this.
If it was ~2mm wider then a NESE 12s4p of 21700 would also fit I think. Was quite sad when I did the math and realized it was just off.
Some discussions on 58kv DD’s and pneumatics here:
If you’re not heavy, they should be fine. But keep your expectations about the performance. And I’m also not sure if the elofty DD’s can sustain 100a motor amps?
So even though the pack can push that much I was going to err on the side of caution and limit at the VESC to 40A or 45A per motor. The specs on the motors say they will handle 50A, but I’m going to wager this will come down to how well heat can be moved away from them.
Yeah- I thought about that but would have probably needed to to move from 12s to 10s since I think that would have eaten up too much of the spare room at the back of the pack leaving things pretty sparse for the BMS + VESCs.
It looks to me like that site is just using the standard bike smartlights available on Amazon. It looks like someone has had good luck with them over on the let-there-be-esk8-lights thread
If the only thing special is the adapter I think I’m going to just get the ones from Amazon and make my own mount.
Impressing writeup!
Very interesting as I am planning a similar build on Switchblade 40 with elofty 58Kv, 12S4p 21700s. Havent decided on wheels yet though, pneumies or TB 110s. This will be my first build, so I will try to learn from yours… Have built ebike before so not totally unfamiliar, but board is still very different in many ways.
Havent started to buy stuff yet, in the planning and reading phase…
Damn that’s one clean detailed post excited for the result I have the same switchblade and the deck feels awesome without anything on it now just imagine with AT
Thanks @Nikos and @amms50 - it is progressing slowly but surely. I have purchased a number of items off the BOM and have only some bigger items left. As parts begin to arrive, I will try and drop in some pictures and reviews where appropriate.
I realized I had not defined lugs for connecting my 12AWG battery leads to my XT60 connector. Since I need to connect to the bolts on the N.E.S.E. pack, these need to handle an M5 stud size while handling higher current. After some research I settled on Wurth Elektronik lugs from Mouser.
These have now arrived and look great, I’ll get some pictures posted once I crimp.
I was being very conservative on my initial criteria for selecting a charge connector. I wanted:
This is how I arrived at the screw top DC barrel connector in my original BOM. However, after seeing this picture I was inspired to look back into offerings from CNLINKO again.
I don’t like the screw hole mounting option in the above picture. I’m doubtful the enclosure material will hold up when having holes in such close proximity. Luckily, CNLINKO offers a clamping style connector for mounting. Additionally they offer some smaller size ports (M16 and M12) with this style. The M12 port (while being smaller and capable of handling 5A) is made of plastic, but there is an M16 option which is made from metal, is still small, and can handle up to 10A. The one criteria it doesn’t fulfill is the strongly affixed waterproofing (since it’s a push cover), but I have relaxed on this requirement a bit. In addition, this port has a very short incursion into the enclosure (most of the structure will be outside) which should allow mounting of this port to a location similar to that in the picture (which is advantageous to my design).
As I mention above, it appears that the Smartlights company is simply making their own mount for (2) standard Xlite100 bike lights. Instead of taking a risk here I just bought (2) of these lights from Amazon. I looked around for a mount that may already exist, but only found these two Thingiverse options for hummie decks:
In this case I’ll need to design and print my own mount for these two lights. I’m taking this as an opportunity to learn Fusion360 (although I still enjoy FreeCAD)
I have only tested these lights under limited circumstances, but I’m relatively impressed by their performance thus far.
This is a tough one. Here’s been my food for thought:
As I mention in the initial post, the Neptune 15 will work as a charge only BMS with per P-Group monitoring. After reading the above two threads (and more) it seems like the other option would be the TinyBMS which would allow for both charge and discharge and (according to my dimensional drawing) barely fit into my enclosure. I’m not, however, totally convinced this is the right path. The statements of “I’d rather a P-Group go low than get thrown from the board” seem compelling. As an alternative, perhaps I can set an alarm with the Neptune app which would alert me when a group goes low. The TinyBMS also has an onboard audio alarm option, which could also be useful if I were to wire it as a charge only BMS. It also seems that the chance of a P-Group coming out of balance is low, especially if you are conservative about the low voltage cut-off setting. Even if a P-group were pulled down and damaged, it seems that the N.E.S.E. enclosures would allow P-Group replacement to be relatively simple. Lots to consider here.
Here’s where I could use some input from the community.
My background reading is from the following articles:
What I’m trying to figure out is how to spec the battery pack cells (based on total current capacity) when using (2) eLofty motors. As per my original BOM, I was planning on using Sony/Murata VTC5D cells (2800mAh with 25A discharge) but it seems that the Samsung 30Q cells (3000mAh with 15A discharge) are the standard for most builds. I also wanted to take a look at Sony/Murata VTC6 cells, as I think these may be the sweet spot. Based on the content in the linked articles I’ve tried to gauge how much max current I can pour into these motors and therefore what the optimal cell should be for this build. I believe my math is sound, but I’m still not clear on what the reliable upper limit of these motors should be.
My one concern here is too much heat since these motors do not have a temperature sensor. I’m not sure how far these can be pushed before the magnets are affected or the wire insulation starts melting.
On the other hand, I want to maximize torque since I’m not using a transmission here and running everything 1:1. So while I’m not really concerned about top speed, I do want the acceleration and (more importantly) braking curves to be predictable and consistent with 6" pneumatics.
I could really use some input here on helping to clarify this subject.
Looking at the characteristics of the eLofty motors and pulling the equations out of the above threads:
Known Quantities
Equations
For 60A max battery output:
For 100A max battery output:
So:
For the motor’s 750W rated power:
For 1500W (per motor) max of 30Q / VTC6 cells:
For 2500W (per motor) max of VTC5D cells:
Equally (if not more) important is total breaking power. Looking at our (3) options:
Looking a bit deeper into the spec sheets gives some kudos to the VTC6 cells:
So, based on the above, it seems like the VTC6 cells might be the best bet. Setting these to a somewhat more conservative setting of 50A battery discharge would result in:
For braking I could then set:
With these somewhat conservative settings, it seems like the VTC6 cells should have enough cushion in them that battery degradation should be minimized. Even in the case where one P-group loses a cell, this cushion should be enough to avoid damage to the remainder of the cells in the group until the offending cell is replaced.
I would love some feedback on the above. I’m slowly purchasing items off my BOM but the next decision really comes down to the battery cells. Thanks in advance.
Let me know if you run into a problem with the antispark.
80A. Everyone runs them at 20A per P group. Mooch (famous, trusted, cell reviewer) classified them as 20A. A lot of web-sites even list them as 20A. They have better capacity than VTC6 after a dozen runs, and are super cheap because of their popularity. I highly recommend them! It’s what most of us use. Better safe than sorry for a first build.
that’s nothing. Most 18650 cells (30Q for sure) are rated for 4A fast charge, and most of us consider them to be safe to up to double that. So 16A per ESC, or 32A total. That still might feel weak, and if you’d rather stop in an emergency with the small risk of burning your board down than hit a car and die, then you could even do 40A in total.
As long as you’re using a BMS in charge only mode (discharge bypassed), then you don’t have to worry about any BMS limits.
Yeah came to say 30Q are tested to be 20A capable. I would go with the 30Q for capacity and current (charge and discharge) sweet spot.
Also for breaking, DDs are particularly at a disadvantage at slow speeds. I would recommend programming in some reverse to help with braking. Here’s a link, first post: eLofty Direct Drive Discussions-read before buying
I bought the dock today so now there is no turning back. The enclosure from Eboosted is next in line. I hope the enclosure is as good in real life as it looks on the pictures.
Looking forward to your pics and progress.
You can get the same from eBay 20 of them for €4, we can argue the quality of tin plating or copper purity but I did not notice any quality issue 20c vs €1.15
