I bought the dock today so now there is no turning back. The enclosure from Eboosted is next in line. I hope the enclosure is as good in real life as it looks on the pictures.
Looking forward to your pics and progress.
You can get the same from eBay 20 of them for âŹ4, we can argue the quality of tin plating or copper purity but I did not notice any quality issue 20c vs âŹ1.15
Remember⌠Nickel can transfer 5A Only⌠Personally i donât like using nikel. Good introduction. And good luck for your build.
VESC Tool identifies the Elofty at 30A, fyi.
VTC6 cells can do 30A per cell when monitored for not going over 80°C, I run them at 20A max which never made any problems. Peak discharge / battery max is seldom reached anyways.
Iâm currently waiting for the Janux hubs with bergmeisters for my 4wd 10s6p build (currently using the esk8supply airless wheels) so its at least similar to yours
Good luck.
Thatâs one sexy build
Nice! What are you doing for braking? Howâs the torque with the 4x4 + 6" setup?
Brakes and torque are good
But I think depending on the terrain/incline you might have difficulties with pneumatics. The rolling resistance of the airless wheels seems to be a bit better, Iâll tell you more when I have the Janux Bergmeisters.
Really Nice, what a beast! I see you have the TB drives. I still havent decided if Elofty 58Kv or TB 75Kv. I read VESC Tool detected the elofty drives as 30A drives. What is the TB drives detected as? Just curious.
I would like to have the flexibility to run Bergmeister or TB110. Will have 12s and only 2wd⌠Will Bergmeisters work with the TBs do you think?
AT is a dangerous game with dd it seems. I suppose attempt with the mindset that it could turn out less than ideal
I threw on TB AT wheels on my AWD 90kV DDs just for fun and surprisingly it didnât all go to shit hahaha. It actually ran pretty decent motor temp didnât get crazy either. Iâm not the biggest fan of AT so I switched back to TB 110s. But itâs doable with the right setup I think.
Holy hell
AT wheels on 90kv DDs?!
you enjoy going at 100kmh?
It helps in your case that you have 4wd.
@longhairedboyâs customers have mixed results with 2wd 75kv DDâs running AT wheels
what switch deck is that?
Or did you paint it blue?
When are you going to finish that rig?
Should be done at the end of the month
Yea word on the street is itâs probably better to go with AWD with the DDs.
Surprisingly the torque isnât as bad as I anticipated either, but again my sample size was one 25 min ride so canât go making decisions of that lol.
I wouldnât say they were mixed. Iâd say that RWD only on TB DD 75KV motors will consistently melt and short with 6" pneumies on them.
Iâm pretty sure the only reason this board survived is because its 4WD and the motors are each getting half the load mine were.
on RWD only anything above 60KV is questionable on DD where pneumies are concerned.
I donât want to take this build thread off topic, do you have one for that sexy beast?
But I just wanted to ask how the clearance was with the TBDD and the switchblade? How did you mount the drives: drop through or top mount?
Iâm not a huge build thread guy but I might throw one together, itâs dropped through with bowery surf baseplates. So clearance isnât an issue
