i have mine set to -69A per side, essentially plugged into a 1p pack, i’ve had little to no issues
putting it back in, the amount of time you actually go over the battery charge limit is very very short, so the chances of causing damage to a pack are minimal
Use whatever braking strength you need for your ride to perform how you need it to. Unless you’re towing a car down a hill, your cells probably will be fine.
Though I believe there is a phenomenon where if the state of charge is in the upper percent or so, higher charge rates can be significantly worse. But this is just an edge case, IMHO getting to a speed high enough for that to matter would likely bring your SOC down to level where that’s no longer mattering.
But aside from that, -20A battery current is a lot of braking, if you’re talking about -20A per motor battery current with at least 2 motors, that is a very significant amount of high-speed brake already.
I set up my VESC using the PC version of the VESC Toolsz
When I want to create a profile from the current values, it shows incredibly fast speed. Maybe he doesn’t read correctly?
I’ve been logging my rides with VESCtool’s RT log functionality. I’m confused about what these are: current_in and current_in_setup. For my latest ride, these two had maximums of 52 and 90 respectively.
I have a p42a battery 12s4p, 10awg wires, xt90s connector. Stormcore 60D+ is configured to 75A battery current and 75A motor current in VESCtool.
I would therefore expect max 150A amp draw but I’m not seeing that, what gives?
On this ride I accelerated full throttle up a hill and went full throttle on a straight road maxing at 69 km/h.
So what are the values 52(current_in) and 90(current_in_setup)? What was my max amp draw during this ride?
Are these values, based on my settings, normal then? The board rides great, I don’t believe it’s too weak, I’m just confused by these values. I drew 52*2=104A max from battery during this ride? Seems a long way off 150A max setting still.
I hope battery is not bottlenecking (wires), but hopefully that’s not the case. Already did around 400km with these settings and everything is still fine, battery/deck doesn’t seem to warm up.
Both can’t actually be 75A simultaneously though. You’ve only set the maximum allowable value, not the instantaneous measured value at a specific time.
My max motor amps being the same might be the limiting factor? I will set it to 100A today and log again and see if there’s a difference. Didn’t understand your second sentence well though.
Brushless motors will only pull as much current as they need to overcome the load.
Throttle controls motor current, so full throttle from a dead stop should give 75A motor current for a little bit.
Battery current is [motor current * duty cycle (aka how fast the motor is spinning)]
So at full throttle with the motor spinning at 25% of max RPMs will pull 75A motor current and 18.75A from the battery.
You won’t ever get to 75A (150A) battery if your motor is set to 75A (150A). You would need to be pulling full load at max RPMs to get close, but even then it’s going to be ~20A less.
Take a look at the telemetry on this ride.
30A motor, 25A battery, 90% duty cycle, single motor maintaining 48km/h. It only needs about 1,000w to overcome the wind load.
