VESC-Tool 2.04: FW 5 >> A BIG STEP FORWARD
Very good info, thank you !!!
It’s the same as wondering why your car isn’t going 100km/h, because that’s the posted speed limit. That doesn’t mean your car goes that fast. It goes however fast it’s commanded to go and the speed changes. It means that your car’s speed should be capped at that value.
That’s what you set in VESC Tool, are caps.
Dont know where ask it but
  • my metr pro show me my wh for only one side (dv6 pro makerX) which setting can solve it ?
  • why my batt A and motor A are so low on my records ? I mean i ride prety hard, 15/20% hills often full throttle, 75kg geared + 20kg board. since im on VSS mode all my numbers are divided by 2 or 3, not a problem at all but when i see others log with 100+ Amp motor/battery i don’t know what to think
(120A motor skpV5 150kv, 12s5p p42a 100A batt)
Thanks and sorry if wrong section
