Thing1/ 1st(good)build /vesc6 /dual 6355 /12s5p
So here is my first build and after looking at the steps I took from my first attempt to now…whoa.
I would like to thank the whole community for helping me get this build together and allow me to create something like this.
speacial thank to @tinp123 @Acido @Sender for telling me about glass frit and @BigBen
hopefully this is not my last build and i will upgrade it soon
So as a 14 year old my money and recourses were slightly more constrained.
Then after learning my lesson on buy cheap buy twice here is what I came up with
Deck: landyachtz clone 40inch (I will change to a genuine one soon)
Enclosure: fiberglass + epoxy (thank you to @BigBen) made for 9two5 deck
Battery : 12s5p 30q with charge and discharge bestech bms (thank you @tinp123)(bms contains an antispark)
Vesc: 2 vesc6 trampa (thank you @Boardnamics and @Trampa)
Remote: mini remote (going to upgrade soon)
Wheels: abec11 97mm
Motors: flipsky 6355 190kv
Trucks: tb218 with riptide bushing
Mounts: marcmt mounts/ janux mounts
Pulleys: 15t motor 32t and 40t wheel(3d printed)
Thank you to @Acido for doing some solder work for me
Not really sure of price or specs but calculator gives 35 miles at 40mph
I was more or less just making a board with decent range, speed and comfort ability. but the main thing was reliablity and not killing myself
edit: did first test just round my garden and so on everything was smooth and nicely done except braking which i will sort out
vesc settings: per motor
45 motor current
-40 motor brake current
40 battery max
-5 regen
what you doing for anti spark? glwb
The bestech bms has an inbuilt anti spark
I approve of everything except the name
It just doesn’t have that ring to it
didnt exactly think for hours about the name
nice so far! I often read sth about the flipsky motors arent that good in long term but also never had them myself :slight_smile:
so i have set up my board and while waiting for my enclosure from @BigBen i have done some indoor testing
the acceleration and speed is fine however the brakes are really weak and i can shuffle the board with my feet even on full brake
anyone know how to help
if your board is on stand still not moving than you apply the throttle to full brake and kick the board with your leg it will move, it´s normal.
if you release the trigger, kick the board again and only than apply brakes it will brake, but as soon as it stays you could push it with your leg again.
oh didnt know that haven really used it at any speed yet so will see when my enclosure comes from @bigben
So I tried the board out down my road yesterday and the acceleration and speed was fine but the brakes were loud and weak
And help
It just sounded like the belt was grinding against the pulleys
Need to up your battery regen current for stronger brakes -5 is really low.
I personally run -16 regen on both my 12s4p 30q packs.
Pictures added
K will try
Is that -16 each or -16 overall
Ahh -16 overall.
With a 5p pack I’d do -10 for each drive.
Also are you having issues with low speed braking or braking at higher speeds?
Keep in mind that these aren’t mechanical brakes and even at full brake you’ll be able to push through it if your really trying. They can’t keep you at a standstill on hills or anything like that.
Low speed braking
I realised but at low speeds it brakes after 3 meters so really weak and loud
Kk just making sure you can always try upping negative motor Amps to see if it makes a difference for ya.
Will see and experiment
So was trying to do that and now for some reason the ppm input isn’t being passed over canbus
When I save it only the vesc with the receiver connected wheels turn
Help please
