That looks like a lot of holes in your deck at kinda critical areas if you plan to jump with it
Ah shit man, I could have told you that. Had the same issue on my last project, but just read your post which was 18 days ago … ![]()
Luckily you figured it out ![]()
Why trampa does ship their escs out with the sensor port set to 3.3V??? ![]()
Because Trampa’s motors run on 3.3V.
Short pressure-wash later:
I removed the battery for this test. Afterwards there were a few drops of water in the enclosure. Not sure if I left those there by accident, or if water did manage to get in. Well, hopefully it only happens when washing.
On some surfaces the vibrations are insane, my glasses were shaking! But the 9" wheels definitely helped, will be interesting to see how the Airs compare.
But damn, mountainboarding is fun! Like really fun! Kinda wish I just bought an Apex predator instead of spending all this time building my own, lol.
Also idk how but I managed to climb this icy hill. I was so surprised I asked my dad to film it:
Nice man. Certainly not afraid of getting her dirty.
I do not think I’ll ever have the confidence in my waterproofing to pressure wash a board! Compressed air for me.
Does compressed air work well? ![]()
Well enough. You can buy it in pressure pack cans too (and safe on electronics if you get dust in enclosure). I’ve got the pressure pack cans at home but if i ever go to my brother’s place I’ll use his compressor.
Bad. Ass.
Killing it dude!
That Is a TANK!! it looks really nice, great work!!!
Thanks! Quite lightweight for a tank. Definitely forgetting about the battery in a backpack idea for the foreseeable future lol
I use an DIY electric mountain for downhill and I prefer to have my battery in my back pack for weight distribution. I use 3 break out points with fuses in case I fall or just get off my bike and forget about the battery and just rip it. I’m really interested about these nese packs. What is holding the cells tight together? Is it the neoprene style material on the back of the strip or the screws somehow? Thanks
Yeah, there’s neopreme behind the nickel coated copper tabs that hold the cells tight. But it looks like it might not be tight enough. I’m reconsidering using NESE for this now, since the vibrations while riding on uneven ground are definitely more extreme than what I felt on my urethane street build ![]()
I’ve decided to not go with a 12s6p NESE. See the discussion in my other build-thread about the arcing issues I’ve experienced:
Also, some of the salvaged 40T cells I bought from Nkon have physical dents / bulges on the negative terminals. So I don’t have enough cells for 12s6p + 12s3p for my brother + 12s4p for @RDs . The box I’m using is large enough for a vertically-oriented 12s7p, or for 2 rows of stagger-stacked 12s4p batteries. Now, I have enough good cells for RDs’s 12s4p and for a 12s8p, so I think that’s what I’ll go for.
Question is – do I connect these 2 4P rows as a single 12s8P battery, or as 2x 12s4p batteries with their own BMS? Having 2 smaller batteries sounds nice, because then I could just remove one if I want to decrease weight for jumping
On the other hand, I’d need to charge them separately, and that could be quite annoying… What do people think?
I had a 4wd board that had two seperate escs powered by two seperate batteries with their own bms but i charged them together through one charge port. It was a Meepo AWD GT.
My knowledge of batteries is poor so not sure if it’s possible but maybe you can have two 12s4p batteries with their own BMS connected in parallel (to enable you to remove one for jumping) that can be charged together if connected to same charge port?? Just a thought? Might be a shit thought haha
Edit: unless you just meant that if they were disconnected you need to charge them separately. In that case, yes a bit annoying and everything i just typed was a waste haha.
That would definitely be a safe option for charging them. But then when connecting I have to make sure all p-groups are fully charged so that they’re at the same voltage level. It’s not a horrible idea tbh.
I want to mount a shredlight at the front of my board, but because of the angled deck + wide baseplates, I can’t use regular shredlights mounts. Their action mount that uses the go-pro mount would be perfect. Anyone know where I could find a mount like the one xboard sells in Europe?
Search Amazon on metal or aluminum GoPro mount. There should be something to be found.
What about 3d-printing a mount? For a light, it should be sturdy enough ^^
It would need to survive me tightening my truck bolts, lol.
Why you need it to be fixed on the mounting holes? You have a trampa deck, you could basically just use screws and bolt it down where ever you need that light to sit. Definitely easier and cheaper to find a metal mount with different hole pattern than the baseplates have.
Just my thoughts.
