Use red but only a small amount. Works for me.
Great thread Raisins!
Thanks! @Simeon has just finished the final 12s4p battery for it too
Here is a photo album of it being built:
Also shoutout to @Zach for selling me his FlexiBMS, it works!
I also have a green davega on the front now
Will take some sexy photos of the complete build once the battery arrives.
ooh, thats nice! I got a switchblade coming next week, so this was a good read.
Wow, I thought I managed to build a decent battery but this makes me feel I still have a lot to learn.
Yesterday my Bestech BMS started exhibiting the same issue. And I finally figured out what was wrong:
One of the p-groups instantly goes to full when charging. Took the cells out, 2 of them are definitely sus:
I wonder what made them go bad. Guess Iāll have to replace all 3.
I also noticed that there are nasty black marks on the tabs of my NESE modules. Should I be concerned @Agniusm ? Theyāre pesent on the other p-groups as well.
PMJIā¦IMO those marks indicate that the cells were bouncing in the holder, disconnecting/reconnecting and arcing each time.
Are these modules used in a board? If individual cells momentarily lose contact due to vibrations, minor arcing can occur. After arcing you get high resistance due to extra oxide in the way and these tabs might see high temps.
I have the modules bolted shut when in operation. That being said, this is a urethane build so the vibrations could have been pretty extreme at times
Clean the strips with a bit of alcohol and then check them out with a good magnifier or loupe. You should be able to see the surface pitting from the arcing.
Arcing also can draw significant current from the cell. Not sure how much they like it.
Could you explain how that works?
In short, this:
To sustain the arc, a considerable amount of energy is required. Intuitively for me it seems that the cell sees both the normal load + the arc load, hence the extra current.
Thanks. I donāt think it works that way though.
The arc is sustained by the rising voltage at the gap due to the systemās inductance. I donāt think we can trust those waveforms to be accurate for anything other than the particular scenario they were considering. Having said that, notice that the current and voltage for both scenarios in that illustration multiply out to about the same power level.
When you say āarc loadā what do you mean? The load is whatever is connected to the leads at that connection point. The load cannot change just because there is arcing. If itās a resistive load the resistance stays the same. Discharged caps will still have the same capacitance. The inductance and resistance of a motorās leads will not change.
The voltage at that connection will rise up to a certain point, āspikeā, for the reason mentioned above and I donāt know what the current level is due to that.
Arcing into leads connected to a MOSFET in the off state will only result in the tiniest amount of greater current flowing into the MOSFETās gate. Arcing into a resistive or capacitive load could result in more current flow but only for microseconds, at the most.
Since the arc lasts only a tiny, tiny fraction of a second I donāt think it can result in any kind of appreciable average current draw from the cell.
Sorry, missed thet. I doubt arcing will occure at 4.2V. Could be oxide?! Have you tried cleaning it? Also you could try 2000 grit paper rub
Yeah hit comes off mostly if I lightly sand it. Iāll try doing that this weekend to see if it makes a difference to my range. My remote says I use up 24Wh/km which should give me ~22km range with my battery, but IRL Iām getting only 10km
How are you riding? I donāt even have that high of a number with my 8" mtb and i weigh 100kg.
With my 100mm hubs Iām around 7-9 wh/km
On my mtb 17-19wh/km
Probably just my 9" wheels which arenāt fully pumped up for more traction in the snow. Also I ride aggressively. (Using this battery on my MTB at the moment)
Ah i thought that the 24wh/km are on your thanes
Arcing easily occurs all the time with āmechanicalā vaping devices using just a single cell. The button on the device presses a contact up against the cell and a spring separates them when the button is released. Each time that is done an arc mark is created.
Some designs can minimize the size of the mark but itās always there.
The arcs are created by the inductance of the system, creating a higher (sometime much higher) voltage to try to keep the current flowing as the contacts separate. You can create large arcs with very low voltages if the inductance is high enough.
When two contacts separate the arc can start when they are a just a tiny distance apart, a millionth of a millimeter or whatever. This is a gap easily jumped by 4.2V. Then the inductance keeps increasing the voltage as the gap increases in width until the arc can no longer be sustained.
