This will be an on-going build thread where I share the progress on my travel build for Carve PDX. The goal is to get at least 30 km of range (~20 miles) out of a dual drive board I can go fast with, and still carry on a plane. Think of it as the better version of my very first DIY, Blue Board. I got exactly 2 weeks time to finish this, so let’s go!
Let’s start with the part selection, and why I chose what I chose ![]()
- 12s3p Molicel P42A battery built with NESE modules. Each module is a 2s3p, which means it contains 6 cells. 6 x 3.7V nominal x 4.2Ah = 93.24Wh, which is right below the 100Wh limit imposed by most US airlines. (EU airlines allow slightly more).
Landyachtz Switchblade 40" deck & @eBoosted enclosure. This enclosure should have just enough room for my battery, dual ESCs, some accessories, and a flexi BMS. And of course, I just love the Switchblade deck, due to its looks and concave that makes it perfect for downhill or cruising. I got my deck skinned by @EreTroN with an artwork by Aenami!
Message him if you’re in the EU and want a custom deck
3DServisas Fat Boy 260mm Surf Rodz hangers & Bowery Surf adjustable baseplate. Surf Rodz baseplates move the hanger further back than Caliber ones do, which helps against wheel-bite, which the Switchblade is notorious for. Luckily 3DServisas makes compatible hangers, so I can use their gear drives
- 3DServisas Mini Urethane Helical Gear Drive V5. 14:36 ratio. At the time these were the only urethane gear drives available, and I couldn’t resist getting them during the black friday sale. They should also be much quieter than steel gear drives, which is nice if I travel to somewhere where I don’t want to draw too much attention to myself.
- Unikboards branded 6355 Maytech 190kv motors. I will be reverse mounting my motors to avoid debris ruining them, and I can’t fit any larger on these trucks. Besides, dual 6355 is plenty of power on a urethane build. 190kv for speed, and because at this size my ESC will be able to power them to their max anyway.
- Boa 100mm Constrictor wheels in 83A, Jungle green. Shouldn’t really support this company, but I wanted a 100mm kegel wheel for torque and range, and there aren’t that many options available. I snagged them in green from Onsra California. They’re waiting for me in the US, so in the meantime I’ll be using my brother’s white Boas.
- Trampa Vesc 6 mk3 ESCs. Got these refurbished from @seaborder for cheap, but I think I’ll be swapping them out for a Stormcore 60D+ because it has an integrated antispark switch, and smaller footprint.
FlexiBMS. Sold out unfortunately, so I might have to route my balance wires outside of the enclosure and use a dumb BMS in the meantime
- Freesk8 remote. Hopefully @DerelictRobot has a Dong waiting for me by the time I arrive in Portland. Will be using my friend’s old Flipsky VX1 in the meantime.
Davega X. Got one in green just because I think it will match the build perfectly
But I think Frederick from EboardSolutions has me covered, should arrive on Friday I think.
