I think the rings are here somewhere, if not, I can post soon, these were made for superstars long time ago, so I will be making some that fits better on MBS
So the widening Iām familiar with. Planning on widening mine.
But I want to mainly know about the flange lol.
Thanks. Looks amazing from this picture. Is there a place I could follow up development?
I couldnāt font a thread here on forum
Thatās an awesome idea. I have tuned my settings a little better now, so iāll definitely try that for the next attempt
I think itās there also, but will see if I can find and upload again
Did you try fivestars out at all? They take 9" hubs well and 10" hubs with a bit of hang over of the hub. These look sick and I want to try 10" wheels out bad.
You know Iām cheap lol
But if this donāt work I will probably get them. I wonāt be running 10", they probably will take a way too big hit on range, and Iām kinda scared of pumping them higher than 24 psi on these printed spacers, but will use for the 9" that are coming
That looks so awesome, I love it!
I would be worried out clearance, though.
One bump and the motors get ripped of ![]()
Put some hot glue over it, to prevent shit from going inside the usb port. And no it wasnāt all at once. Layer by layer, left to right so nothing seeps in.
Oh boy lol
At least it isnāt black hot glue, that would probably pull the usb port out
Could you elaborate? I removed black hot glue from the Bluetooth module on my Xenith to install a Xenigotchi. I didnāt think much about it other than being surprised at the color Iām not used to. It was pretty simple. I plan to use more (regular) hot glue to attach the new module per BKBās suggestion.
Idk⦠my black hot glue is the strongest shit Iāve ever used, it is incomparable to the clear hot glue Iāve used in the past
Iām stupid but not that stupid lol.
I just put the hotglue over the port the first time a few minutes ago. It doesnāt really need it as I donāt really have dirt inside the enclosure but i thought it wonāt hurt.
Iām always surprised how many pebbles get in my hummie enclosure
The only ādirtā i have in my enclosure are the remains from the foam gasked that i have cut a piece out to make room for the connectors of the vesc.
Stuff like this and thatās it.
Haha my motors look like theyāve seen war. All of this is in the name of getting low. No other board Iāve ridden is this stable
Maybe you should buy some MASSIVE STATOR extremely durable titanium coated motors
Then you wouldnāt have that problem /s
Same though, on my hummie my motors are pretty much horizontal, rear mounted. They are BEAT up
We use black for holding down things against the enclosure And our high temp hot glue for anywhere we need the glue to seep in for a hold on things like the ppm cable or BMS connectors
You may wanna try a higher wattage glue gun.
Yeah Iām really impressed with how well these flipsky motors are holding up. To be fair, I dont put nearly as many miles on this board as my others.
