for something like spring trucks a small motor attached to each spring which could effectively turn the board for you
i dont know much about programming but maybe with a remote which can be turned in the full 360 degrees and somehow implement it into there
Lol no problems with your idea, just everytime I read spring trucks I remember good ol Springy with the ever so innovative anti-wobble springs attached to each side of hanger
You really would want to add a complicated steering system to the trucks instead of doing it with 0 extra parts and just tank steering with software? At that point I would make a dedicated robot/RC car instead of trying to add it onto a esk8.
I guess your idea was ok too though, given mountain board trucks are something people would have. You could make an RC car using one or two of them and take the springs out and put a motor to turn them instead.
That is good because then you only spend money on parts that are also useful for esk8.
You could use the boardnamics AT gear drive for it!
Or you could try to design some full suspension trucks and take the steering and attach it to a servo motor instead of the leaning. That could be useful for riding once reconfigured too.
always had an idea for stabilization for mtb boards using tiny stepper motors on each spring which auto adjust you stopping you from tipping over
then somehow after maybe 15 degrees or something you are able to turn by just using your legs
Haha crazy idea I don’t think adjusting the tension on the truck’s sides is a good way to go about that. The more traditional steering dampers are definitely the way to go.
