Push it in
I wanted to put together a quick guide for where to get some push fit pulleys that I have here and have used, mostly from our community vendors but it should be mentioned that many of the commercial brands have their own versions which may or may not be useful to us. Buy from our dudes though
This is going to be focused around the ones I have and my experiences with them, that way I’m not pulling info out of thin air and misrepresenting anyone. Vendors, I welcome you to come on and correct anything I have written or that has changed since my versions were bought.
In no particular order:
@BuildKitBoards BKB Modular pulley https://buildkitboards.com/collections/pulleys/products/modular-pulley-set
32t - 44t and modular. I found that the pin shape is absolutely amazing in a genuine abec core. I have not tested this one with a clone core. The Kegel core likewise fits gloriously with no play.
@dickyho Dicky Kegel pulleys https://www.ebay.com/itm/DIY-eletric-skateboard-longboard-5M-36T-40T-44T-pulley-for-for-kegel-wheels/303177972063?hash=item4696d0b95f:m:mtksP96DjF4r2adCbTSiSKA&var=602141977991
36t - 44t and modular (can be converted into a bolt through if you want that).
There is some slight play in the pins for this pulley, I solved this by wrapping them tape/heatshrink - would recommend this to retain the integrity of your core. With that said, the price is amazing.
@3DServisas Fatboy pulley https://shop.3dservisas.eu/collections/fatboy-pulleys
36t - 44t Kegel and Abec. The daddy of push fits in my opinion. The machining is excellent, the fit is incredibly snug and the price makes baby Jesus cry. If you’re looking for no compromise it’s this or the BKB pulley.
@EboardSolutions Pulleys https://electricboardsolutions.com/collections/pulleys-belts-mounts
36t Kegel, 36t - 40t Abec. You will see from my pulley that mine came from the first batch, these were not perfect but have been more than usable. Since this version the pins on Abec core have been improved greatly and the width of the pulley supports 15mm belts now. Very good option all round and delivery is super fast from this store.
@haggyboard.timo Haggy glass fiber & nylon pulleys https://haggyboard.com/products/36t-abec-11-flywheel-compatible-street-drive-gear-belt-combo-kit
36t only - kegel and abec. These are super inexpensive, fit really well into all wheels and Timo will have them in a box before you even finish clicking the pay button. If you want to dip your feet into the push fit pulley market this is the way to do it.
@moon Moonberg’s pulley.
This was a really tiny production run, I think there’s four total out there. I have spoken to captain moon a second ago and he’s happy to make more. Price to be announced. There’s also a Venom Mach 1 adapter about to become available too.
These fit great, stems might need shimming with tape if your core is tired. Price will likely reflect that however knowing moonface.
There are many more! Let’s get some community knowledge together and put the bolts away.
