I could be wrong. but 90% sure I’m not. pretty sure it’s just the different pinouts on v6 vs v4 and uart vs ppm.
Unfortunately, with Flipsky, that’s not very uncommon and you always consider the possibility
QC costs money, ya know
I’m aware of that now.
Had to fix some Flipsky stuff to make it work.
But I’ll admit after inspecting and fixing there F ups it’s working good now.
yup can confirm the Rx and Tx pins are swapped… I just repinned some BLE modules yesterday
which press fit kegel wheel pulley works for BKB dual kit? so far i’ve only seen bolt on ones.
BKB doesn’t have kegel adapter anymore.
dickyho, Fatboy and EboardSolutionsboth are either 15 or 16mm, all require longer axle
haggy would require 6001 bearing to fit on 8mm axle, which can be done, but i want something easier
I haven’t seen moon’s pulley, unless someone sells it
It should be possible to use caliber etruck if I want to use 15mm pulley?
OMG please use @Boardnamics BN184 trucks over Caliber E
It’s literally completely compatible except ten times better. Not seven times better — a full ten times better — and only slightly more expensive.
My man! Rope him in!!!
Not only that but axle-modded Caliber 2 are better even than Caliber E.
Caliber E suck and bend easily.
Thanks! will look into that
The Boardnamics 184 is everything CaliberE should have been — but wasn’t.
Anyone with a gt2b can give me receiver dimensions? Looking at enclosures for my new build
I don’t have one anymore but I recall it being both wider and longer than the mini receiver.
The mini receiver fits in a space 18mm wide x 27mm long and height depends how you attach the wires
I’m going to guess from memory that it fits in 22mm wide x 37mm long
[quote=“frame.b022, post:3615, topic:30355, full:true”]
not really cheaper.
wait, has this been covered?
ive heard rumours of a ‘Polish esc’ …anyone else hear this/know what it is?
3dservisas
ah thankyou. Is it any good?
Not released yet.
