That’s exactly what I’ve been needing this whole time, a kickstand for my skateboards.
I am going to move to china and help them with this crap…
No kickstand not for skateboard!!!
Let me know if you need help with your Kickstarter.
honestly 4 wheels isn’t very stable
but next payday I’m buying 8 gummies, I’m hoping that should do the trick
Hey Guys, Noob all over here! Decided to build my own DIY board. However being UK Based we have poor roads, poor pavement and shitty police. Which means I have decided to give up on my 80mm kegal wheels and look at getting some SR Foamies. However I have been told by SR that I will need an adapter for my caliber 2 Trucks to fit their wheel. Would anyone have a clue where to find the adapter to get my conversion done?
Don’t buy SR foamies. They’re still selling the defective core.
More info here:
And here:
I have read a few posts about their core. Would anyone recommend an AT wheel I can add to my trucks?
Such a huge range/topic. Start here:
5" pneumatics from hoytskate
Hi anyone know what this noise is
It only comes from when motor
Must resist the urge.
What ja mean
Is the belt on? Does the noise happen with it off? Sounds like a belt way too tight followed by a slipping grub screw on the motor pulley, but this noise alone makes is hard to diagnose.
Nah direct drive
Switch which ESC it’s connected to, does the noise change sides?
What are the results of the BLDC hand test?
Does it happen with no wheel or wheel adaptor?
Good call will try that now
Have had some issues with this vesc so gonna look into that
When did you last lube you motor beatings
Uuh never
There are 2 bearings and don’t have any lube
Can you link on amazon
Confirmed it def isn’t the can might be stator vesc or bearings
Can I use wd40 as bearing lube
Or bike lube?
